SOURCE: LSE7806A Top Load
The belt is still attached to the transmission right?? It sounds like the brakes may be stuck. Or are both belts off and the motor still trips out?
SOURCE: maytag stacked washer dryer lse7806ace
Take the belt off the transmission pulley and see if you can turn it by hand. It will agitate on direction and spin when you turn it the other direction.
Put the timer to spin with the belt off and see if the motor will run. There may be a problem in the start switch on the motor letting it start in one direction but not in the reverse direction.
Special tools are required to remove the transmission and brake assembelies. You also want to make sure there is nothing sticking through the holes in the basket causing it to lock up such as a nail or screw that may have been left in a pocket.
Post back with what you find.
Thanks/Mike
SOURCE: replacing a siphone break
Disconnect unit from its power source before servicing!
The lower half (washer) can be pulled away from the upper section, allowing full access to the unit. Remove the front panel by taking out the 2-phillips head screws at the bottom of the front panel, pull outward at the bottom of the front panel to disengage the hanger clips from the top panel. Remove the 2-3/8"hex head screws from each corner of the side panels connecting to the top panel. The top panel can then be tilted up and back on its hinges, so that acces may be gained to the siphon break. 4-5/16" hex head screws secure the 2 halves of the siphon break to the back panel and are accessible from the outside of the back panel.
Follow the link below to see an image of the siphon break assy. along with ordering information.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60BFrigidaire+%60AWashingMachine
Please rate my solution in accordance with your satisfaction of my job performance.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
SOURCE: Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
SOURCE: Top Load Stacked Washer /
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
