Kenmore 24032\24036 Top Load Washer Logo
Charles d McClosky Posted on Feb 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 800 series starts to agitate before reaching correct water level, also while filling up with water it pumps some out but will eventually fill and wash through the cycle. It appears to not be spinning all the water out of the clothes during the spin cycle as before this problem arose
William H Weigold
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 18, 2022
William H Weigold
Contributor
Level 1:
Answers
Questions
0
Helped
1566
Points
There is a YouTube video that will show you how to replace the water sensor switch. On the Kenmore 800 series, it's the switch that controls the temperature. The video was made by Appliance Video.com. It's very simple to replace the part. I bought my part at Amazon. Not only did I have the washer agitate before any water started to flow, but at the end of the final spin cycle, it started to add water for a few seconds.
Steven Brandon
Level 3:
Master:
  • Kenmore Master 462 Answers
  • Posted on Feb 13, 2018
Steven Brandon
Kenmore Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117795
Points
1705
Clutch needs to be replaced that is why it is not spinning out. There is a clear rubber hose that goes from the fill valve on the top left of the machine down towards the bottom of the tub on the right side under the cabinet. Check and see if that hose has a hole in it of possibly came loose on either end.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Jul 10, 2007
SOURCE: Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Anonymous
  • 1028 Answers
  • Posted on May 01, 2008
SOURCE: kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Anonymous
  • 1776 Answers
  • Posted on Aug 27, 2009
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Anonymous
  • 10 Answers
  • Posted on Oct 08, 2009
SOURCE: Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Anonymous
  • 15935 Answers
  • Posted on Sep 14, 2010
SOURCE: Kenmore 70 series washer won't fill during rinse cycle
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Kenmore 800 washer agitates before filling with water
This could be caused by a couple of problems. The water level sensor could be bad so that the washer thinks it's got water in it already or the timer could be bad. If the washer starts to fill after it starts agitating then the timer would be the problem.
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
1helpful
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
1helpful
2answers
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
1helpful
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Kenmore washing machine won't stop filling with water
yes the water level switch controles this does the machine quit filling when you turn it off if so eather the water level switch is bad or the rubber hos attached to it has come off
Alexander
vince
