It makes a loud squeaking noise everytime it prints. My toner is Brother brand. I checked the paper tray and there is no way to make the letter drawer larger or smaller so I do not think the paper is rubbing and having difficulty feeding through as one post suggested. Any other ideas?
SOURCE: Squeaking
that's a mechanism issue inside..it's going to fail quite soon, so you may not have this problem for too much longer.
SOURCE: Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
SOURCE: My MFC8460N Brother won't print. It makes this
Gears on the tray is broken, or the gears that lift the tray. (thus the clicking noise). And the no paper is due to the actuators underneath not being activated because of the non lift.
SOURCE: Repeated paper jams from the brother hl2070n after remove toner
Oleg Andrukh
IT Specialist
PhillyCopiers.com
215 364 3774
SOURCE: My brother HL-5240 won't feed from paper tray,
Pull out a paper cassette, lift up the printer and under you see paper feed roller (it is rubber), just clean roller with cloth and water or alcohol.
