SOURCE: Can't figure out how to connect a subwoofer to my RCA RTD315W
HI,the rca system should have a sub pre out socket,plug a phono cable into this then to input on your sub and set volume to half way,also make sure the sub is set to on in the setup menu on the system.
Hope this helps.
CABLE GUY.
SOURCE: RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
SOURCE: RCA 5.1-Channel 250 Watt Home Theater System - Model RTD209
Unit was working fine,took a movie out,put in new one,but would not play.Tried hitting open button ,unit will not respond,all other functions working ok.
What could be the problem,is it worth fixing?/Is there a reset button somewhere on unit?
SOURCE: can't find a code to
We would be happy to help with that. Here is a list of someof the codes that we have for RCA home theater systems: 703, 852, 772, 638, 704, and 727.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codesfor your RCA home theater system provided above. Press the pound (#) button, the modelight should flash three times. Checkthat the code works by trying several different functions on the remote to makesure it will properly operate your RCA home theater system. Keep in mind that some codesmay not be compatible with your equipment. If this is the case, please try theother codes listed for that device until you find one that is compatible withyour equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
