RIM BlackBerry Storm 9530 Smartphone Logo
Posted on Jan 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reload software 552
Installing software in computer
Gulzar Cherichiyil
Level 2:
Sergeant:
  • Expert 252 Answers
  • Posted on Jan 16, 2013
Gulzar Cherichiyil
Expert
Level 2:
Sergeant:
Answers
252
Questions
11
Helped
52671
Points
805
Download blackberry device software from blackberry official website and follow the instruction
You need only data cable,and PC to install blackberry device software
5 Related Answers
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Mar 06, 2011
SOURCE: my blackberry 8520 phone is
Welcome to Fixya. You can download the latest version of the BlackBerry software from your wireless service provider's website or from the link below to fix your problem.
BlackBerry Software Download
Thanks for using Fixya.
Anonymous
  • 425 Answers
  • Posted on Jan 21, 2011
SOURCE: Hi my name is dean
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Anonymous
  • Posted on Nov 30, 2010
SOURCE: How to resolve "reload software:552"
I had this on a bold 9000 when trying to update the firmware. The only way i found around it was to remove the battery and plug it into the computer and reload the old firmware. This method worked for me after playing about unplugging and re-plugging, whether it will work on the 8520 i don't know, good luck!
jay khan
  • 138 Answers
  • Posted on Mar 26, 2011
SOURCE: my bb 8520 screen shows
software has crashed. need softaware reloaded.
Anonymous
  • 61 Answers
  • Posted on Apr 12, 2011
SOURCE: my blackberry is showing reload
Try the following steps to reload the software for your blackberry. You will need BB desktop manager (which you download from blackberry.com. Good Luck
  1. Verify that the BlackBerry® Desktop Manager and the current BlackBerry Device Software (for your BlackBerry smartphone) is installed on the computer.
  2. Remove the battery from the BlackBerry smartphone. Do not re-insert the battery.
  3. Open the BlackBerry Desktop Manager on the computer.
  4. Connect the BlackBerry smartphone to the computer using a USB cable.
  5. On the BlackBerry Desktop Manager main screen, click Application Loader.
  6. In the Update Software area of the Application Loader, click Start.
  7. Click Options. This allows you to add or remove applications from the BlackBerry smartphone.
  8. Select the applications that you want to install.
  9. Click Next.
  10. Click Next.
  11. Click Finish.
  12. When the application load process starts, insert the battery into the BlackBerry smartphone.
How can i reload error 552 on my 8520
make sure ur desktop manager and software is installed then Remove the battery from the BlackBerry smartphone .....Open the BlackBerry Desktop Manager.....Connect the BlackBerry smartphone to the computer without battery ie only on charger...Click Application Loader....Under the Update Software heading, click Start....Click Options. This allows you to add or remove applications from your phone Select the applications that you want to install.
Next.
Next.
Finish.
Once the application load process starts, insert the battery.
then u r ready to go
1helpful
What do i need to do if my blackberry curve displays a message saying reload software:552?
I have had the "Reload Software: 552" error on 2 BlackBerry Curve 8900s. When it occurred again (last night) this is what I did:
[ WARNING! THIS WORKED FOR ME, BUT I WAS LUCKY & IT MIGHT NOT WORK FOR YOU! ]
1. Reboot your BB: alt-rightShift-del
2. Start a software reload from the Windows desktop, via the BB Desktop Manager.
When the reload started, I would get a screen on my BB showing 2 computers talking to each other. After a few seconds, this would crash into the 552 error.
3. 3-5 seconds into the software reload, CANCEL the desktop.
4. This should freeze the apps on both the desktop and the BB. The BB should still be showing the 2-computers.
If you do anything on the desktop at this point, the BB will crash into the 552 error again.
5. Terminate the desktop app processes via the Windows task manager. There are 4 RIM/BB processes to shut down.
6. At this point, the BB Desktop Manager app should be gone, and the BB should still show the 2-computers.
7. Now, start the BB desktop manager back up again, and intitiate the software reload again ...
A 4thumbs up will be greatly appreciated. Thank you for choosing FixYa!
1helpful
Screen says reload software: 552 How to fix it?
I suggest you do what it says, reload the software.
Get a microusb cable and plug it into your computer.
Download and install BlackBerry Desktop software, this will allow you to reload your software.
1helpful
My blackberry is showing reload software 552
  9. Click Next.
  10. Click Next.
  11. Click Finish.
1helpful
552 error
Reload software: 552 or App Error 552, known issue in Blackberry. To resolve, upgrade to the latest available BlackBerry Device Software version provided by your wireless service provider to resolve this issue.
Complete the following steps:
  9. Click Next.
  10. Click Next.
  11. Click Finish.
    Hope this helps!
2helpful
2answers
Well my phone will not turn on and it says reload software:552
You can try updating your phone's operating system.Download the latest Desktop Manager here http://us.blackberry.com/apps-software/desktop/. Plug your phone into your computer by USB and the Desktop Manager should automatically start the update process. I believe Blackberry OS is up to version 6 now.
1helpful
6helpful
2answers
My phone is saying reload software 552
on my blackberry curve 8520 has reload software 552 on front of the bb screen when i turn on my blackberry / it also will not power off ..can u please help me .. how can i fix my phone
Sep 21, 2010 • Cell Phones
45helpful
3answers
Reload software : 513 comes with my blackberry 8520 curve what can i do
i'd attempted 10 times USB pwd, and now my phone s/w was all whipped off. msg on screen is reload software 513, plz help. i'd just got my Curve 8520 3 days ago...
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
