Check alternator fuse , it's should be a high amp fuse . Question is did you give some one a jumb start , this could happen , another thing to check is your ignition fuse and your ignition switch , but first check all fuses . Including the big once under the hood and inside the car . Good luck and I hope this helps
SOURCE: rav 4 won.t start
I would look at the key. Is it the original. Didm you get an add on alrm system or remote start switch?
SOURCE: mini van wont start
Sounds like starter selanoid, but first make sure battery connections are clean and tight, if sure they are then turn on headlights and try to start if still clicks and lights dim its starter.
SOURCE: 2003 Chevy Impala periodically won't start
Try under the dash, attached to colum is a switch that the rod goes into from your ignition key switch, that may need to be adjusted tword your steering wheel just a touch, they go out of alignmnet from time to time
SOURCE: 2007 chevy cobalt ls won't
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
Fuel injectors may be dirty.. or plugged.
The car just sitting there may have caused the gas to go bad which may have
given them a head start on plugging from the get go. Get some cleaner for it.
When the dash lights blink, is it unlike anything you've seen it do before?
check the detail :
