Westinghouse LTV-32w4 32.02 in. LCD HDTV Logo
Ahmed Faiz Posted on Jul 10, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Recently i got Westinghouse LTV-32w4 HDC wide screen DVD Combo 3 TV. Service to view NTSC or ATSC.So Can i Convert this NTSC to PAL from TV hardware.
  • Ahmed Faiz Jul 11, 2007
    Dear sir
    I think you could not understand my comment.
    My problem is Westinghouse LTV-32w4 HDC widescreen
    DVD combo (flat screen TV) Tuner system is only compatible for NTSC or ATSC. In my region we have PAL system. So i need to convert this NTSC system
    to PAL system.
  • Anonymous Mar 18, 2014
    Only audio. No picture. Only the on - off button works. Unable to adjust volume , Chanel's , or minue.
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 114 Answers
  • Posted on Sep 05, 2007
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
114
Questions
0
Helped
48167
Points
208
Unfortunately this TV will not support 576i, the standard PAL resolution and therefor you will not be able to use a PAL TV tuner with it. The only other options are to use any HD device such as an HD TV set-top box or HD DVD player as these will connect to the TV via HDMI at an HD resolution, alternatively you could use your PC as a TV tuner (if it has a TV tuner inbuilt or attached) as your PC will send a VGA signal to the TV at 1360x768.
Anonymous
Level 1:
Scholar:
  • Contributor 39 Answers
  • Posted on Jul 11, 2007
Anonymous
Contributor
Level 1:
Scholar:
Answers
39
Questions
Helped
80787
Points
93
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
  • Anonymous Jul 11, 2007
    Hi there. Ok.. I see now ! This tv is TV system antenna / NTSC & ATSC *1 in US from the manual. PAL uses a completely different frequency, framerate and resolution !
    The only way you can use this tv set in europe with pal, is to buy a seperate cable tuner. You could even connect a VHS video externally, use the RCA video outputs and tune channels via the VHS ! That would be a cheap way to get it working.
    There is no ways to get the internal tuner to work with pal, i can assure you that.
    Hope that helps you a bit more ! Thanks, cheebster. Please ask if there's something else you're wondering about.
1helpful
Our TV/DVD player (LTV-32w4 HDC) is just out of the 4 year extended warranty we bought. The TV works fine, but the DVD player will not start up. When a disc is inserted, it seems to be trying to start...
Hello
According to your complaint post, the fult is due to its DVD mechanism itself. It will be best to replace the DVD tray mechanism [ plastic made one]. You can bought it from most of the electronic spare part shops at your town. But the model fitted with Westinghouse will be very difficult to get. Anyway try to get it. The fault is with loading tray mechanism itself. OK.
2helpful
My Westinghouse LTV-32w4 HDC has went green. Sound is perfect, but the screen is solid green. Doesn't matter whether it's the cable box or the internal DVD. It's solid green.
The Tuner signal board is dead.The Tuner signal board,that the board,where the incomming broadcasting signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
How to remove dvd drive for Westinghouse LTV-32w4 HDC 32.02 in. HDTV LCD TV/DVD Combo
http://www.retrevo.com/support/Westinghouse-LTV-32w4-HDC-TVs-manual/id/278ci973/t/2/
First you would have to get a service manual, this shows you all you need to know about the unit. Without it, it is very difficult to even remove the case. but once inside, it is basically a simple task, to find the drive, remove the fastenings, and the Cable, obtain an EXACT replacement HDD, and reverse the procedure, it may pay to format the HDD first, FAT32, I believe, although your manual will be more specific.
Westinghouse LTV-32w4 HDC No signal how do i rest the signal
Hello, this all depends on what input signal you are trying to see, there is differnt ways to reset the signal, I would love to help you resolve this issue personally, please email me at [email protected] so I can better assist you. Also if my assistance is helpful please rate my help on this website.
Blue screen, no picture, audio works fine. TV
I have the same issue. I am thinking I need to replace the T-con board. Did you get your fixed and what did you need or do?
2answers
My house was robbed while on vacation and my Westinghouse Widescreen DVD combo was stollen. Model #SK32H590D. Bought at Target on 4/27/08. Can you tell me the serial no.? Please do not post the no. to the...
You'll have to either go to Target and have them check their records, or if you registered the TV, you can try and contact Westinghouse to see if they can help you. No one else would have a record of your serial number.
Westinghouse DVD/TV combo has no sound
i'm sorry i didn't notice the "dvd/tv combo". the dvd mech inside the tv will need to be replaced.
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Remote control
need to set up a remote control to my tv. I lost instructions and codes.
1helpful
4answers
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
