While the phone is attached to the charger, check the cell temperature. If it gets warm, the cell is activating its internal protection. Try this: when the cell loses power, take it out and put it in a freezer for a few minutes, then reconnect it to the phone. If the charge returns, the internal circuit is reacting to internal heat. Get a new cell.
SOURCE: Non Supported Battery
Try a new battery. Many phones do this when the battery goes defective.
It is also possible that the battery control circuits in the phone are defective. This is less common.
Jerry G.
SOURCE: I want to confugure internet
From the menu tab
Select Settings
Select Wireless and Networks
Select Mobile Networks
Select Access Point Names
Here you can add a new APN as per you provider settings. You can also edit the existing APN values by selecting the APN.
SOURCE: Have few problems with Samsung Galaxy 5 GT-
Ifthe battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
SOURCE: can i install android os
hi,
contact your nearest service center to install android.....
thanking u
SOURCE: I have Samsung Galaxy 5 GT-15503. Android 2.1.
Wi-fi has been known to eat up the battery life on ALL devices it's on.
That's just the way it functions.
If you really want to save battery on your phone, disable wireless, bluetooth and 4G connections you may have, dim the screen to it's lowest setting and change the display timeout to a very low time.
Btw, it cant be the battery that's worn out. The phone is pretty new, and and we had same problems a couple of months ago, but i dont know what fixed it then... problem
