Question about LG 37LC7D 37 in. LCD HDTV
On/off problems with my LG 37LC7D TV. It is hooked up to Direct TV
When I turn on the TV and Direct TV box simultaneously with the remote, the Direct TV box comes on normally but the TV generally does not have sound or picture. The on light goes from red to flashing green. If I turn the TV (only) off and on enough times, it eventually comes on with both picture and sound. I have tried unplugging the TV and waiting 15 seconds and plugging it back in, but it didn't help. HELP
    Top Expert:
  • LG Master
  • 85,216 Answers
You need to contact a local TV repair service, UNLESS you have the tools and the repair manual to repair it yourself, it will take diagnostic work to determine what is the cause, one thing is for sure you have a defective circuit board.
Posted on Jul 17, 2017
6ya staff
SOURCE:
Anonymous
  • 10 Answers
SOURCE: LG 32LX1D 32 not turning on
Hi, I think you have to get it checked out by a profesional, unpluging your appliances is a good idea but damage can also ocuur the moment you plug them back on. If you want to try it could be that a fuse is open there not normal fuses inside (small chip fuses surface mount)
Posted on Aug 24, 2007
Anonymous
SOURCE: MY lg 32lx1d is not turning on..
I had the same sympton on my tv...it worked fine one day and the next day it would flash a green light a few times you would see the screen power on, but still be dark then the power light would go red. I couldn't do anything on the tv no menus or sound. It turned out to be a bad power supply, a new power supply will run around $200-300 - in my opinion it wasn't worth fixing. My neighbor was able to fix my tv - he repairs electronics - ended up cost me $100.00 - its been running for 7 months now no problems so far...I can have him fix this for you if you are in the area - shipping makes this to expensive..he is located in south jersey...or you can try a tv repair shop ( i called for this but they wanted between $75-100 to just look at the unit + repair cost - i would of been back to the 200-300 range) let me know if you need help...John
netplus@comcast.net
Posted on Oct 09, 2008
Anonymous
  • 36 Answers
SOURCE: LG 50PC3D PLASMA WILL NOT TURN ON
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you save $300 least!
Posted on Mar 15, 2009
Chi Chu
  • 8457 Answers
SOURCE: lg 37lc7d with no picture or sound but green light comes on
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Posted on Feb 10, 2010
Jaime Hernandez
  • 2337 Answers
SOURCE: My LG Plasma 42PC3D turns on and off repeatedly. I
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Posted on Sep 24, 2010
How to fix my lcd tv and magic remote?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 29, 2015 | LG 47LW6500 47 3D LCD TV
The sound on my View Sonic N3735W does not come on when I turn on the TV. I have to turn the TV off and on between 2 and 5 times before there is sound
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Feb 21, 2018 | ViewSonic N3735W 37 in. LCD TV
Tv resolution issue
check zoom on either your tv remote or direct tv remote. someone has hit the zoom button . Its can be called zoom,picture, picture size. You want to get it back to normal. this can be done by hitting one of those buttons repeatedly until you see normal come up.
Apr 07, 2012 | LG Televison & Video
No sound coming from my Vizio Model #E320VL HDTV. Tried everything I can think of. I have Direct TV and it just stopped working one day. Any advice?
We just had the same problem with our tv, we switched tv's and it still didn't work. We reset our att uverse box, and the sound works. I don't know how direct TV works, but the problem may lie there instead of your TV
Sep 09, 2011 | Vizio VF550M 55 in. LCD HDTV
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
My direct TV is saying "not supported mode" and no
It sounds like your DirecTV box is sending a signal to your TV that your TV does not support. The front of your DTV box should have a button that says "RES." Press the button until the picture shows up on your TV. Make sure to wait about 5 seconds between each press to let the TV catch up. Generally, you will want the highest resolution that your TV will support.
If this was helpful, please rank me a 4.
Mar 08, 2011 | RCA DIRECTV Satellite Remote Control
How to program my direct tv remote to my vizio tv
Visio TV codes: 004 or 031
Turn on the TV
1. Press [TV] button and [SEL] button simultaneously for 3 sec.
2. Point the remote controll toward the TV and enter code.
TV will turn off when correct code has been entered.
3. Store the code by pressing [TV]
Oct 10, 2010 | Televison & Video
Hooked up converter box and stations are all working but sound is coming out a hissing.
Use the volume control on the remote for the converter box to raise the sound level. Adjust the TV volume with the converter box turned all the way up then reduce to normal listening level with the converter box remote.
Jul 29, 2009 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Sound goes out
punjabie if you have a receiver box for direct tv try unplugging the box then plugging it back in after about 10 sec that should fix the issue, if not then i would call direct tv may be something with their box
Aug 03, 2008 | Apex Digital PF2020 20" TV
I have a samsung bn59-00599a remote for samsung plasma fs and hughes satellite box i am unable to use remote for stb i also have rca remote controller rcr412c for use
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Nov 26, 2007 | RCA RCR412C Remote Control
LG 37LC7D 37 in. LCD HDTV Logo
108 people viewed this question
Ekse
RONALD CARTER JR
