The detector was plugged in, my dog bumped into it and now it is a constant alarm. I've tried pressing the reset button and tried plugging into another outlet, tried removing the battery and putting it back in. Once the battery is put back in, it is a constant alarm. The only way to turn it off is by removing the battery. Any ideas on how to get the thing to reset?
SOURCE: carbon monoxide detector err code
You are going to hate this as much as I did!
In the manual you will read this ..
Manual for Kidde Nighthawk C02 Detector
On page 13
Unit Malfunction
In the rare event that your alarm malfunctions,
it will alert you with a short “chirp” and the red
LED will flash once every 30 seconds. The
digital model will display “Err” as shown in
Fig. 6.
Seven years after initial power up, this unit will "chirp" every
30 seconds to indicate that it is time to replace the alarm.
The unit will not detect CO in this condition. Please replace
immediately.
SOURCE: KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
SOURCE: kidde Carbon Monoxide Alarms
YES!!!! If this unit is working properly you should not be in the house. Maximum allowable safety level for an 8 hour period is 50! If you think it's working properly call the fire department! This will cause dizziness,nausea,etc. Let your fire department find the problem! If you don't believe me follow this link to owner's manual but do it quickly: http://www.kiddeus.com/utcfs/ws-384/Assets/KN-COB-B(9CO5)en.pdf
SOURCE: Kidde nighthawk carbon monoxide detector started
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Crystal Robinson
PR Coordinator
Kidde
SOURCE: what does an err code E03 mean?
Malfunction signal - Component failure. An intermittent "chirping" alarm will sound every 30 seconds, and an "Err" message will appear on the digital display. The only solution is to discard it entirely and replace with a new gas & carbon monoxide alarm.
