YARD MAN 42 '' RIDEING MOWER WON'T START PROBABLY SAFETY PROBLEM
safety switches that all riding mowers seem to have include a seat/brake safety which means that you have to be sitting in the seat or the brake must be engaged for it to start. also there is the blade engaged safety, which means the mower will not start normally with the blades engaged.
if you meet those conditions check the switches themselves
non safety related, do you hear a click or a clunk when you turn the key to the start position, this is the starting coil pulling in to send power from the battery to the engine starter, all safety switches will interupt power from the key switch to the starting coil
if you hear the coil energize and the engine does not start you have low battery voltage or loose connection or some other mechanical problem
