Question about Samsung LE40R74BDX 40 in. LCD Television
Removing stand from tv
I have a Samsung LE40R74BDX 40 in LCD and want to take the stand off so I can wall mount it. How do you remove the stand?
  • 8 more comments
  • Anonymous Dec 12, 2007
    I have a LN-T527F and am trying to remove the stand for wall mounting by taking out the four screws. The screws spin but do not seem to to come up so I am unable to remove the stand. I've tried a magnetic screw driver - no luck.
    Is there some trick I'm missing?
    Thanks.
  • skyroad Jan 18, 2008
    I have the same problem. I have a samgung 46in F86bd. Exactly the same. The screws spin but do not come out, and hence I cannot remove the stand for wall mounting. Very frustrating. Any solutions?
  • nigar Apr 15, 2008
    thanks for the messages, what we did was to remove the bottom screws and then the half part of the stand is still there am i suppose to open the screws from the back. please inform,
  • twotubz Jun 07, 2008
    TO REMOVE BASE STAND (I have LE3788BD so assume it's all generic)
    Stay calm.
    Samsung's illustration and instructions to lay our TVs face down on soft cloth can cause a nightmare if you are trying to do this on your own unless your a clever fxxxker with magnetised screwdirvers.
    2 people are best for screwing techniques and your basic screwdrivers especially when you need to angle the TV so gravity helps the screws fall out
    You need to fully remove the 4 screws by helping them out, they will not fall out once loose. They are inaminate pieces of metal.
    Gently grasp the neck of the stand,
    while unscrewing each screw keeping upwards tension on the neck (a slight jiggle jiggle may also work)
    you should feel the screw biting on the thread rather than spinning around
    once you experience the intense joy of the first screw falling out your on a multiple rush home with the stand slipping out of the hole easily once the last screw is out.
    Happy screwing.
  • Anonymous Nov 02, 2008
    i have a 46 inch lcd samsung and have the pogo stick looking thing stuck on the bottom how do i remove it?
  • i_am_fun06 Nov 18, 2008
    how to remove the base from a samsung 40inches LCD
  • Anonymous Nov 27, 2008
    THANK YOU! This helped me alot.
  • pugg2000 Feb 05, 2009
    32" samsung here , same issue . any ideas?
  • Anonymous Mar 29, 2009
    how do i remove the tv stand
  • Anonymous Aug 23, 2018
    Thank you for sharing this useful information, I will regularly follow your blog
    shell shockers
UNSCREW the FOUR (4) screws on the back panel (marked with an "S" next to their recessed holes.
Work with the panel screen-side up (ie on its back - we did it with the LCD on the bed), and just JIGGLE the stand back and forth until the screws drop out. This make take some doing, but using force is a no-no (as the screw mounts are only plastic). Obviously the screws MUST be undone, so just keep unscrewing them while someone else jiggles for you.
Thats it. The plastic cover (from the manual & warranty bag) covers the hole.
Posted on Feb 09, 2008
After spending 2hour trying to get the stand off my samsung LE37R88D I finally managed! You need to pull the stand very hard, while unscrewing at the same time, hope this helps the rest of you :o)
Posted on Jan 19, 2008
I too had the same problem tonight?????  After a few attempts of trying to pull the television off its stand I finally realized the four screws at the back need to come out completely, so I tipped the television backwards until all of the screws fell out, then lifted the television off
Posted on Mar 30, 2008
I have a Samsung LNT4665F and did everything mentioned before on this thread. Nothing worked and it seemed like I was making no progress with loosening the screws. Here's the trick that did it for me: Use a #1 Screwdriver that comes to a severe point on its end. Most phillips head screwdrivers are #2s and the grooves are too thick to turn the screw. As a test, try your screwdriver on the screw that is visible next to all the A/V inputs. Do not take this screw out! Just see if you can turn it. It's the same type of screw that is deep within those "S" holes.
I unscrewed while the TV was upright and on the stand. I then flipped it panel side down on a couch and jiggled the stand until all four screws fell out.
Posted on Aug 11, 2008
I thought the superglue idea was neat but then I thought what if I leave a mess, why not try sticky tape first.
Just a bit of insulating tape put sticky side out on a PH2 crosshead screwdriver, push it home and pull on the tape and out they came came.
No need to put the tele on its face or its back, and the stand stayed in place after the screws were removed - it's a good fit - but don't leave anything fragile underneath just in case.
Good luck
Jerry
Posted on Nov 28, 2008
Be careful not to scratch the frame around the edge of the screen while you're trying to get the stand off. What worked for me with a Samsung 37A552 was to lie the TV across the gap between two soft chairs, with the screen facing the ceiling. Slide yourself in under the TV and the 4 S screws will just fall out when you unscrew them. Then the stand pulls out easily.
Posted on Sep 01, 2008
I have the 46" version of the TV.
Unscrew the four screws marked 'S' on the rear of the TV at the bottom (you'll need a Phillips screwdriver).
We had to unscrew the damn things for what seemed an eternity, but if you tip the TV upside down and tilt it, eventually the screws fall out. The fascia supplied with the TV can then be fitted over the hole.
Stay cheerful,
Dave & Eileen
Posted on Sep 06, 2009
  • Samsung Master
  • 2,015 Answers
How to Attach or Remove the Stand for Samsung LED TV https://www.youtube.com/watch?v=qcA2c7O0E0A
Posted on May 10, 2017
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
Go to youtube and there is a video on how to open it.
Posted on Sep 03, 2015
    New Friend:
I am able to remove three out of four screws from 46" Samsung LCD however not fourth one. I looks like stuck inside. I dont know what to do. Any ideas?????
Posted on Mar 09, 2010
Ive just removed the base stand off my 40" Samsung and all you hace to do is remove the 4 screws that are marked S and the base slides out
But the screws must be fully removed from the sockets before the stand comes away so a magnetic screw driver or something simular is what to need to fully take them from the sockets.
Hope this helps as some of the prevoius replys really helped me
Happy Screwing Folks
Posted on Oct 27, 2008
Here is your problem guys your trying to take the wrong screws its not the 4 at the bottom of the stand its the four that are marked s at the back base of the tv under the sansung moddel number sign x
Posted on Sep 06, 2008
We had same problem . The solution: Follow the manual directions and loosen up the screws, they do not come out.
Then turn TV, UP side down (Screen facing the ceiling), the screws will fall out. BINGO. We used thermocol from packing as 4 props to keeep TV (screen facing UP)
Posted on May 25, 2008
  • reido4456 Dec 17, 2010
    Thal's the way to do it, TV upside down (screen facing upwards to ceiling NOT downwards like the manual says.
DO NOT TAKE THE BACK OFF OF THE TV! There are 4 screws marked "S" - simply loosen these while pulling down lightly on the foot assembly - the foot assembly should come off as soon as the 4 screws are removed!
Posted on Apr 15, 2008
I found these articles very useful, another tip in my case I already had it mounted on my wall and didnt want to take it down so I used a tiny dab of super glue and held it on the screw for a second before gently unscrewing them and pulling the screws out with the screwdriver I used loctite super glue Its the best ive found
I am having the same problem right now. I hope you have figured it out since, but if not, this is what i got after downloading the manual off the Samsung website. 1. Place the TV face down on a soft cloth or cushion on a table. 2. Remove four screws from the back of the TV. 3. Separate the stand from the TV. 4. Cover the bottom hole with a cap.
Posted on Aug 20, 2007
THIS IS HOW YOU DO IT !!   ( 1 PERSON )
ONLY SLIGHT ALTERATION TO ABOVE . HAD THE SAME PROBLEM AND SIMPLY.
HOLD UPSIDE DOWN WITH 1 HAND AROUND ROUND STEM ABOUT 5MM ABOVE CUSHION OR SOMETHIN SOFT AND UNDO SCREWS. OBVIOUSLY BE CAREFULL IT AINT GONNA ROLL . HAVE UR KNEE READY OR SUMTHIN ... ON A CUSHION AGAINST A SOFA IS MY RECCOMENDATION .. HAPPY DAYS..   OH YEH AND IF UR GONNA USE IT FOR GAMING BE SURE TO SELECT "1080I" ON UR CONSOLE AND SELECT "GAME MODE" ON UR SAMSUNG WHERE THE COG SYMBOL IS IN THE MENU.. LOVLY
Posted on Mar 29, 2008
Had the same problem . i did get the stand off but the set now does not power up
Posted on Dec 18, 2007
Anonymous
SOURCE:
How to fit swival stand on model le32b554 32inch
There are 4 screws in the back at the bottom centre of the tv. Remove these and pull out the blanking plate. Next insert the base upright assembly into the tv and re screw in the 4 screws
Mar 07, 2010 | Samsung LE40R74BDX 40 in. LCD Television
I have recently bought a Samsung SM2033HD TV and want to wall mount it. I can remove the base but how do I remove the collar that joins the base to the TV.
Your tv is not fully VESA compliant. You cannot remove the collar. There are mounts available that grip the screen instead of screwing into the back. This type will look better.
Jan 10, 2010 | Samsung LE40R74BDX 40 in. LCD Television
How to remove the stand from samsung 860 52"
  1. Spread the comforter out on a flat surface such as the floor.
  2. Step 2 Lay the Samsung flat-screen television face down on the comforter on the floor.
  3. Step 3 Use the magnetized screwdriver to gently unscrew the four to six screws securing the stand to the television.
  4. Step 4 Remove the screws with the magnetized screwdriver. If you do not have a magnetized screwdriver, cover the end of a normal screwdriver with masking tape with the adhesive side out so that it will catch the screw and pull it from the hole.
  5. Step 5 Pull the stand from the back of the television
  6. Step 6 Mount the television to the wall with wall-mounting hardware you can purchase from any home entertainment store.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Nov 15, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Wall Mount for Panasonic TC26LX50
Panasonic will not recommend any other brand as they don't test other brands, its a Liability issue for them, after all if you set falls off the stand your calling them. For a stand, find one rated for you TV's size and weight, try not to be on either end of the range as you want to aim for center of the range. Look for 22-32" and weighted for at least 25% heavier than the set.
Apr 13, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Whilst watching tv after 10 to 15 min screen goes blank but sound ok ,when u turn tv off then back on u get pitcure for about 10 minthen goes off again
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Feb 28, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LCD won't turn on.
sometimes the power cord comes out behind tv , the power outlet is bad in the wall,
Jan 21, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Removing tv stand
Remove the screw and pull the TV upwards.
Have someone step on the stand
Dec 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Tx 26lxd70 panasonic lcd
I had the same issue with my Samsung LN52A550. The 4 screws holding the TV stand are quite small and deep inside the holes. You can not take the stand off without take them out completly. I tried to remove them with magnetic screwdriver, tweezers but didn't help. So, by laying down my TV on its back on my sofa letting the TV bottom and the stand parts outside and lay down beneath to unscrew them again. With the grativity, some screws fall out right away, some may need unscrew a little bit more or shake the stand a little bit. I could say it's a very bad design about this screwing system. So, good luck then.
Jul 06, 2008 | Samsung LE40R74BDX 40 in. LCD Television
How to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
HOW TO TAKE OUT THE STAND
Usually it is in the owners manual, but if not, try removing the screws on the back bottom of the base. Just lay that LCD on a flat surface like a bed and then you should be able to see how to remove the base. usually 4 screws. I haven't seen this exact model though. Good luck. Jay
Jan 30, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LE40R74BDX 40 in. LCD Television Logo
57,673 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
