This problem start intermittently a acouple months ago. It has gotten worse the last couple weeks. The cycle will be comlete and clothes removed and there is no water in the drum. But When I come back the next day or so there is water standing in the drum. It has went from very little water to the bottom of the tub being full this am. I have been running a spin aone cycle to empty before I do a load. A couple of times it has not spun all the water out when washing a load( very few times), and I have had to run a spin cycle to get water out of clothes. We have cleaned out filter basket--not much was in there and there was alot of water this am.
SOURCE: Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
SOURCE: Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
SOURCE: LG WM2077CW (UE error code)
For "ue" an unbalanced load is sensed three times; re-adjust your load in the machine. What is the capacity of your machine, you could weigh your dry clothes........refer manual.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
.....& rate me if helped.
SOURCE: soap dispenser not working
It sounds like the water valve has a clogged filter. Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve. Clean out the filter with toothbrush. Reinstall and everything should be ok.
SOURCE: LG WM1814CW - Water/soap Leaking Under Washing Machine onto Floor
Here is the answer !!! My LG front loader has leaked once a year for the past 4 years. The rubber bellows (a part underneath the washer) cracks and causes the leak. DO NOT LET THEM TELL YOU THAT YOU ARE USING TOO MUCH DETERGENT ... THAT JUST AN EXCUSE !!! The part costs around $12. Here's the link ...
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx?R=1514&searchText=LG%20Washer
