Question about Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network...
What is the Username and Password for a Cavalier provded Zhone 1518-A1 Modem Router?
  • Herman Smith Jan 17, 2013
    If the Zhone 1518-A1 was provided by Cavalier, then the address is:
    New Friend:
192.168.1.1
Default Username: admin
Default Password: c@v@l13r (all lowercase)
This information was valiad as of 01/17/2013
Posted on Jan 18, 2013
  • Elrod McCoy Jan 18, 2013
    192.168.1.1
  • Riphard Serent
    Riphard Serent Dec 03, 2013
    Hi Elrold. What about an update username and password?
  • 7,627 Answers
Only you know your SSID( username)and Security Key(password). You can RESET the device to default settings by pushing and holding the reset button for 30 seconds or so and release. That will reset to default setting. Then you can reconfigure the SSID and Security Key, You may want to write down the info for future use. This may help: http://www.zhone.com/products/1518-A1/
Posted on Jan 17, 2013
6ya staff
SOURCE:
What is the user and password please help me
username : admin
pass: admin
if you are not enter to router conf , you shull reset router and try again
May 30, 2014 | Zhone 1518-A1-NA Wireless Broadband Router...
Change password
1) plug into your router (no wireless)
2) use IE, chrome, ect to go to your default gateways address (192.168.1.1 or something)
3) enter username and password (hopefully default login info applies (usually admin,admin admin,password or admin,"blank" or something)
4) go to the wireless tab and set up name of network (SSID)
5) save or apply settings
6) set up password type and actual password (i reccommend WPA WPA2 or WPA mixed or the likes)
7) save or apply settings
8) hook all up normal and test
Nov 18, 2013 | Zhone 1518-A1-NA Wireless Broadband Router...
192.168.1.1
This information was valid as of 01/17/2013
Jan 17, 2013 | Zhone 1518-A1-NA Wireless Broadband Router...
1518-A! router
Click Start on your computer then Run and type cmd then press Enter.
When the DOS command box opens then type ipconfig and press Enter The computer will the display the IP address that was issued to your computer BUT if the IP address is 0.0.0.0 then your router did not issue an IP address to your computer and you need to repair the network connection.
Oct 03, 2012 | Zhone 1518-A1-NA Wireless Broadband Router...
My Zhone 1518-A1 modem-router keeps loosing internet connection although wifi connected. Is it normal that the internet led is blinking?
Its normal for the internet light to blink, it means that its having an activity.
Try accessing the modem GUI (graphic users interface) and then change the WEP key or security key , if the modem-router is not password protected then just reset it.
You can also change the power values on it
Hope this helps
Thanks
Dennis
Nov 04, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
I need the default username and password for the Zhone 1518-A1 dsl router i cant find it or figure it out please help
192.168.1.1
Aug 16, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
I have a Zhone ADSL2+ 4 Port Wireless Bridge/Router, model number 1518-A1-UK-0MA. it as working perfectly until one day when i turned it ON, only the ADSL LED is lit, no other LEDs are on, nor the power...
Please use the following steps:
1. Remove the router and connect it directly from the pc to the modem.
2. Power cycle: turn the modem off and then the computer for 30 seconds, then turn them both back on, modem first.
3. Check you internet connection to see if it working.
4. If it working, connect the router back up. If it not working contact your ISP for dsl support.
5. Once the router is connected, release/renew the ip address. Go to the dos command type ipconfig/release press enter. Then type ipconfig/renew. Check your ip address, you shouldn't get an ip address starting with 169. If you do, this mean you have a problem with the router getting an ip address.
6. Check you internet connection after the release/renew
Jun 10, 2011 | Zhone 1518-A1-NA Wireless Broadband Router...
Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network... Logo
682 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
