Washing Machines Logo
Posted on Jan 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
My Bosch WFL 2260 front loading washing machine does not drain.
I have checked front filter and nothing in there.
Which other filters should I check and where are they?
Many thanks. Karen
  • Anonymous Mar 12, 2014
    cant get the filter off the bosch front load
Anonymous
Level 2:
  • Expert 142 Answers
  • Posted on Jan 25, 2009
Anonymous
Expert
Level 2:
Answers
142
Questions
0
Helped
57617
Points
316
Sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
How-2-Repair.com
Level 3:
  • Washing Mach... Master 746 Answers
  • Posted on Jul 30, 2013
How-2-Repair.com
Level 3:
Answers
746
Questions
0
Helped
592432
Points
1880
Bosch WFL 2260 front loading washing machine This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Maxx WFL 2260 wash. machine will not fill/spin
Could be the intake valve solenoid, or control panel fault
1helpful
Washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
2helpful
Bosch Maxx 2260 washer won't drain or spin.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
1helpful
2answers
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace [email protected] , [email protected]
2helpful
2answers
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Bosch Maxx WFL 2260
thanks sorry i have no hands on experence with bosch as im in usa and dont have many in my neck of the woods but there are bosch experts in here
2answers
Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
1helpful
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Top Washing Machines Experts
john h
