Everything appears to be working except the screen,it should come on when cam is opened and switched on,it plays the tune to let you know its on but thats it,this happened after taking 3 flash photos,screen has failed before while under guarantee,they fixed it and has worked fine up til using flash again which i dont usually use.
If this has happened previously and been 'repaired' [note the quotes-it is not normally a repair for these small items but replacement] this then would seem to be a fundamental fault with this particular model. Go for a refund or model change
If the tuning light on your Crosley CR66 Rochester radio is not working, there are a few things you can check to try to fix the issue:
Check the bulb: The tuning light may simply need a new bulb. You can try replacing the bulb to see if that fixes the problem. Check the manual for your radio to find out what type of bulb is needed and how to replace it.
Check the wiring: If the bulb is not the issue, it may be a problem with the wiring. You can open up the radio and check the wiring connections to make sure everything is secure and in place. If there is a loose connection, you can try tightening it to see if that fixes the problem.
Check the switch: It's possible that the tuning light switch is faulty. You can try cleaning the switch to remove any debris or dust that may be interfering with the connection. If cleaning the switch doesn't work, you may need to replace it.
If you're not comfortable working on your radio yourself, you may want to take it to a professional to have it repaired.
enter your recovery and wipe your cache and then try to reboot, check YouTube how to enter recovery mode for your model as it is different for most phones.
If have factory amp you have to find the turn ou wre for the amp and hook it up to the amp turn on wire from the radio(bootleg way sound might cut in & out) or go to local sound shop and get a bypass for the amp
Dear Daeva,
CCD Imager of your DCR-TRV33 got defective due to unknown reason. You should go to nearest Sony service shop for replacement of faulty part.
