Question about Westinghouse TX-42F430S Television
Westinghouse tx-42f430s won't power on
I have a westinghouse tx-42f430s, i was watching it this morning and when i turned it off via the power button on the tv i got a slight shock and now the tv wont power on. i know it is recieving power because the orange power light is on as long as it is pluged in. i have tried unpluging it and pluging it back in several times but nothing works.
i am sorry if i seem like a mad man rambaling on but i am desperate to get my tv working again. i would be trully grateful for any help. thanks
  • Anonymous Mar 12, 2014
    My Westinghouse 42" TV will not turn on. At the front of the TV the power light is orange. I opened up the back ab=nd could not find any bulging capacitors or anything thing else that looked abnormal. I have also tried hold powerswitch after I unplug from wall.
  • Anonymous Mar 31, 2014
    orange light on front panel is on but tv will not power up when on button pressed
    Sniper:
  • 96 Answers
More likely it's because of power circuit of your TV set. If you are not trained enough in repairing TV sets, appeal to your local repair center
Posted on Jan 25, 2009
    Master:
  • Westinghouse Master
  • 450 Answers
There is a defective electrolytic capacitor (470MF/16V) on the main board that went bad, it will causes intermittent, slow, or not power up, the location number of the cap is not marked on the board, please see the attached photo to locate it.
westinghouse tx-42f430s won't power on - westinghouse-tx-42f430s-power-vqmgfgmng2tcguhwrvsy1ivk-5-0.jpg
Posted on Apr 30, 2015
Hello I have a Westinghouse TV model number TX-42F430S Sometimes it comes on and sometimes it does not. It has an orange light in the center below the W emblem in the center of the TV. when the TV actually comes on that same light is blue Is this the reason that the TV will and will not come on sometimes? is it a power issue mayb a power circut issue???
Posted on Aug 07, 2011
6ya staff
SOURCE:
I have a white westinghouse 40 inch tv model vr4090 and the tv wont come on it shows the power indicator turn from red to blue but no picture or sound
Westinghouse tx-42f430s wont turn on fix repair - YouTube
? 5:29
https://www.youtube.com/watch?v=DdfLu5RdVEQ
May 12, 2014 - Uploaded by After Hours Tv & Pc repair
Westinghouse model # 32H1G1 won't turn on , but If I unplug the TV and wait for a ... -tx-42f430s-42-inch-lcd-tv-appears-bricked-595806.html ... I have a Westinghouse 40" TV that is working, but sometimes it won't turn on.
Westinghouse LED LCD TV Repair - YouTube
? 12:32
https://www.youtube.com/watch?v=DGg5iuFEfdM
Feb 8, 2014 - Uploaded by INSIDEHARDWARE CHRIS
Westinghouse Model: LD-4680 Similar (LD4655VX LD4255VX ...Samsung LCD TV Repair - TV Won't Turn On - How to Replace Power Supply ...
40 inch Westinghouse lcd tv black screen help - YouTube
? 1:39
https://www.youtube.com/watch?v=tKLRihGgZAs
Nov 21, 2011 - Uploaded by Jason Flynn
Dec 19, 2015 | Westinghouse Televison & Video
Westinghouse tv turns on power light blue works for 3 minutes then turns orange
This is going to be associated with your inverter or your display board. Some cases they are the same board. You will have to take this apart, find the board and then find a replacement.
Apr 13, 2014 | Westinghouse TX-42F430S Television
Westinghouse model tx-42f430s won't power on
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Sep 24, 2012 | Westinghouse TX-42F430S Television
MWe have one of these tvs and this morning it wont turn on although the light in front is red and it still wont turn on
I had the exact problem and couldn't do the factory reset or another reset that a Westinghouse tech told me to do over the phone - BUT I FIXED IT! This is what I did. With the TV facing me and power on and connected to my cable antenna (like normal - ready to watch TV) I took my right hand and started pressing all different buttons on the side of the TV in different order at random. All of a sudden the big W came on the screen so I called back Westinghouse technical assistance and she told me go to menu - then TV - then scroll down to channel search. Since all my cable channels are on channel 3 on the TV - the search found that channel and the picture and sound came on and works fine!
Sep 05, 2011 | Westinghouse TX-42F430S Television
Unable to get signal input when i connect my pc
There are several fixes for this problem.
1) You can unplug the TV for a few minutes and try again.
2) You can turn off the TV then hold the Power button down for at least 10 seconds (resets the processor)
3) Go to the settings menu, select factory reset.
Good luck
Jun 07, 2009 | Westinghouse TX-42F430S Television
Won't power up past the W logo.
Try hitting the input button and selecting the correct source. Mine is YBPBR1. That should get you a picture!
Nov 17, 2008 | Westinghouse TX-42F430S Television
Channel number display will not turn off
are you using the TV tuner of the TX-42F30s or are you connecting via setup box
what happen if you change channel
the unit can be reset to factory mode.
Nov 15, 2008 | Westinghouse TX-42F430S Television
TX-42F430S Lock up on power up
I have a similar problem with my TX-42F430S; Mine freezes when changing from Comp 1 to Comp 2. unpluging and waiting was the only fix. Just recently my TV just started turning off(after about 30min of watching) and the led will flash blue. I need to unplug for about 10min before it works again. Getting frustrated and I have contacted Westinghouse to send for repair. only had the TV for 3 months; connect to Roger Explorer HD box.
Nov 02, 2007 | Westinghouse TX-42F430S Television
Televison & Video Logo
2,105 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
