Question about Timex T79051 My First Outdoors Kids Watch White Dial Black Nylon
Changed watch battery good but hands still don't move
    New Friend:
  • 14 Answers
Battery in backwards
Posted on Jan 18, 2013
6ya staff
SOURCE:
The watch hands don't move
the battery will need changing digital and analog watches normolly have two battaries.
Nov 27, 2012 | Watches
Please stop telling people Rolex watches don't tick.
Yes, absolutely correct , all automatic watches tick and the fake Rolexes just tick a bit slower so it is more visible.
Oct 08, 2012 | Rolex Watches
I have a FOSSIL mens wristwatch model # AM3423. I recently had a watch repair person replace the battery. Battery type and charge confirmed. I received the watch used as a gift from a relative who was...
Quartz watches stop working most often for one of three reasons: (1) dead battery; (2) dirt in the gears blocking the train; and (3) a bad crystal. This is the order in which I typically troubleshoot watches.
If the watch isn't working after you change the battery, first check to see that the stem is fully pushed in. A watch movement can shift just enough inside the case that a stem sometimes looks pushed in, but isn't quite in far enough to re-engage the movement. Pull out and push in the stem a few times to see if that changes anything.
Next, assuming that the battery is indeed fine, look closely at the second hand. Is it moving at all, even a tiny bit? Hold the watch up to your ear. Is there any kind of "chunk" sound about once every second? If you can answer "yes" to either of these questions, a speck of dirt has gotten into the movement and is preventing the gears from moving freely. It doesn't take more than a a big spec of dust to cause this. Sometimes, advancing the time will move the gears enough to cause the dirt to fall out. Some watch repair places also have a special machine that spins the hands rapidly to blow out or compact any dirt in the train. It's usually not economically rational to have the movement professionally cleaned beyond this point.
Finally, if you don't hear anything coming from your watch, the battery is good, and the setting stem is pushed firmly and completely into the watch movement, you may have a bad quartz timing crystal. It does happen, and when it does, the only repair is to replace the entire watch movement. Sometimes, that's affordable; sometimes, it just doesn't make sense.
Sep 20, 2012 | Fossil AM3424 Wrist Watch
MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Oct 21, 2011 | Michele CSX Diamond watch
Question 1:Well,this guy was gonna throw away this watch,so i asked him if i could have it.Now i have a Guess G65023G watch that doesn't work. I want to fix that. Problem 1:The minute hand turns when...
Well, thats a good watch. however, based on the conditions of your watch, probably, its battery is not dead. some of its mechanism were not in place or broken. Repairing it is advisable. Afterall it has no scratches like what you've said. So go for repair men!
Jun 09, 2011 | Guess G65023G Watch for Men
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
Swatch Irony Battery replacement will not work
mcdevito75 here, I am thinking your watch ran fine before the battery change. It sounds like the new battery is not makeing good enough contact, you can try, removeing the battery and cleaning the contacts in the watch carefully with a Q tip, dip the Q tip in anything containing alcohol cologne, rubbing alcohol, perfume wet the Q tip good, then sqeeze most out of the Q tip as not too saturate the battery contacts, also clean the battery itself, the oil on your fingers could give it a poor contact on the watch. The stop watch section doesn"t take as much battery power as the second hand. You may also be able to jump start your watch also, You"ll need a needle and a magnifier glass, With the back off your watch, right in the middle of the movement, just below where the stem (winder) goes, you"ll just see part of a little gear, this is the hour hand gear, see if you can gently move that gear just a fraction, place the needle between the teeth of the gear and try to move it as gentle as possible then se if the gear will move on it"s own., be very carefull with the movement. Swatch watches are collectables. If you don"t feel comfortable doing the above, look for a small watch repair shop in your area for help.
Jul 17, 2010 | Swatch Irony watch
I have a police chronograph watch about a year old if that and the chronograph dials have reset themselves at random points does anyone know why and if so is there a fix? many thanks david
hi,
all you need to do is pull the centre bezel out (to where you adjust the time) and by pressing the top button the chronograph needle will move round. Once it is the correct place simply push the centre bezel back in.
Hope this helps.
Duncan
Dec 17, 2009 | Police Watches
Timex T79051 My First Outdoors Kids Watch White Dial Black Nylon Logo
169 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
MrFixitSTTL
pacdave
Are you a Timex Watch Expert? Answer questions, earn points and help others
