SOURCE: Hi! My LG Intellowasher fills up with water, but
after pressing star button water does not fill and after 10 sec all the temp lights flash
SOURCE: i have a lg intellowasher 7kg wd-8015c (front
the water pump is sending a signal to the pcb telling it there is a fault clean the filters and wheel on the water pump
let me know how you went
sonic boom electronics
SOURCE: My LG intellowasher 7kg WD-8015C
Most common,Water supply okay, Door closed properly,Child lock not switched on....? Good Luck
SOURCE: LG front Loader Intellowasher 7kg WD-8015c has
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
