4 inch wide vertical band just off center, sometimes striped, sometimes a plain bar, sometimes disappears after pressing in on the cable. Attempted to reseat the ribbon but that did not work. I'd like to find the part but can't find it listed anywhere? Can you provide the part number/where to buy this?
SOURCE: Black 3-4 inch wide Stripe
Contact Samsung and demand a replacement television. With my situation, they had me take it to a repair shop and get an estimate. I was originally going to get nothing, then after several correspondence, only the parts for free since it was out of warranty (not too far out of warranty) and pay for labor. They decided it would be too expensive and difficult to find the part. They ended up letting me pay 350 for the same tv but 2 years newer. It is definitely worth the price since the labor alone would cost that.
Hope this helps!
SOURCE: broken horizontal stripes except for 6" band
there are two convergnece boards in this tv. one is called the convergence (DCU) the other is called the convergence amp board. this amp board has the (STK`S) on it and ids your problem. in most cases we repair this board.
good luck :)
let me know if you need more info?
SOURCE: I have a Samsung 52
hi,
it is time to replace the panel. the micron tube in the panel has already worn out.
SOURCE: I bought my Samsung LN40B530 nearly two years ago
It cam be the LCD panel, T-CON board, or main board. Very difficult to narrow down to exact baord without manual and proper tools. I would first find out if the switched 12vdc feeding theT-CON board is OK, also try reseating the ribbon cables on the T-CON board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
http://www.mediafire.com/?zzjygannjty PDF download
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
