Washing Machines Logo
Posted on Jan 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg wf 801 won't fill
I take water line off cold inlet put on hot inlet tell machine to fill with hot water ok but will use cold cold water for rinse cycle , is this a control board problem
Level 3:
  • LG Master 17,130 Answers
  • Posted on Jan 19, 2013
LG Master
Level 3:
Answers
17130
Questions
0
Helped
3631732
Points
52372
Yes , It can be related to the control board, but first of all please make sure that there is good water flows in both the inlets, check the flow after the valve , ensure that the inlet filters are not clogged and check all the connections from the harness to the valve and panel
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Aug 06, 2006
SOURCE: Washer fills slow only in the rinse cycle
The first thing I would do is remove the hoses from the inlet valve and make sure the screens are not clogged in the valve. On some models the valve will compensate on fill opening both hot and cold. It will not do this on cold rinse. Before ordering any controls check this out first. If it's still the same I tend to believe it's a valve problem. The buzzing you are hearing is the valve. Catriver, post back.
Anonymous
  • Posted on Sep 02, 2008
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Anonymous
  • 1028 Answers
  • Posted on Sep 20, 2008
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Anonymous
  • 70 Answers
  • Posted on Feb 24, 2009
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Anonymous
  • 3361 Answers
  • Posted on Apr 02, 2009
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
1helpful
LG WF-T653a - The cold water only dribbles out when trying to fill the tub, (the hot water comes out fast) which causes an IE error constantly stopping the machine. Any ideas what I can do, please?
yes che3ck the water inlet valve for bad connection or blockaGE, IT MAY ALSO BE BAD IN THE COLD WATER COIL, U CAN TEST WITH A MULTIMETER. FOR RESISITANCE
Washing machine won't fill
This can be due to a clogging of the inlet valve as the water flow is restricted. You can remove the water line to the washer and check the flow , then check if the inlet valve works after the power is switched on the washer , If there is no flow to the drum then the inlet valve is faulty provided there is power to the valve or the main controller is faulty
1helpful
PE error for LG Washing machine WF-t7269 KN. Cleaned the water filter still shows error.
LG's 'PE' does indeed stand for (water) Pressure Error'
(following is pre-typed!)
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
I have a LG WF-T753A washing machine. The hot water is not working, but has in the past - cold water is fine. When it goes to fill up with Hot only, a slight hum, and then it stops, but no water. Have...
Check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
1helpful
2answers
Does this machine need hot water or cold - Tricity Bendix aw 1200
Hello , I can help , if there is only 1 water inlet hookup it will be cold and some new machines heat the water on there own , if there are 2 water inlets it would be best to connect hot and cold to unit , if you do not have a hot water line available it should still be ok to put a Y adapter on your cold water line to both connections on your unit. Let me know how it goes. Phil
2answers
I have an LG washing machine model WF-T755A After washing completed, if water not turned off at taps, the unit slowly fills up with water. The last time causing it to overflow and flood the floor
Water inlet valve is not sealing off 100%. Replace inlet valve (the part where the hose attached to the machine). didn't find that exact model listed so couldn't give you a part number. Usually LG's have a separate valve for the cold and the hot. If you turn off one valve where hoses connect to household plumbing you should be able to figure out if it is the hot or cold. (most often it is the cold) Leave both valves off when not using washer until fixed. (note: usually on LG washers, if you have unit connected to power and the door closed, if it fills with water as your machine did, the water level switch will trip and automatically pump the water out, even if washer is not in use and the power is "off".)
2helpful
3answers
22helpful
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
