The info>menu>mute>power on takes you to the engineers menu.
(Start with the TV switched off)
Use the direction keys, down to RESET,
then the right direction key performs the reset, the TV switches off.
On power again, the setup sequence runs for both TV and DTV.
I had exactly the same problem as p111upr and this fixed it.
Phil.. to reset: Info>Menu>Mute>Power Button make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings. if you just want to reset freeview.. 0 0 0 0 then press the colour buttons in sequence.. im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
Put set into standby then press in sequence (info) (menu) (mute) (power),
this puts set into service mode. Scroll to (RESET) and press right arrow.
You will see 'wait' message appear. After a few seconds set will go to standby.
Press power to bring set on and follow on-screen instructions. You
should now have everything working correctly.
NB. Do not alter any other settings whilst in service mode.
They can easily fix a simple DTVv board in home. remember if you access the service menu don't mess with any other settings, just use the reset function. many people get tempted to play with the hidden settings in that menu and can really screw the set.
Got exactly the same thing. Will have to try these altough not to happy going into the engineering menus.
With the other solution with the 0's and the colour buttons. Where do you enter this ? Is it when the TV is in standby or when it's on DTV mode ??
Many thanks
Paul
I've tried the above but it dont work for me.... my tv just turns on with a blank screen then switches off by itself and turns back on again without going to the service menu.
dom6918 - when you say if you just want to reset freeview..0 0 0 0 then press the colour buttons in sequence.. Is this done with the TV switched off?
other tv works upstairs both off the same aerial but cant tune freeview in downstairs
Not receiving any signal or station since the recent change to new digital channels on freeview.
can only receive one channel, neither volume or channel selection works MENU LOCKED
