My Maytag MAH 24 gave me an error message of "nd" and it did not finish through the rinse and drain cycle. I paused it and powered down and when I powered it back up it now just makes a weird humming noise. Since there is still some water in the machine, the door won't unlock and it won't drain/spin. Is there a re-set button on this machine so I can get my clothes out?
I also have this problem. to get the door to unlock, just unplug the washer and it should open in a min or two. you will hear a click. you may have a mini flood but at least you can get your cloths out and bail out the water. my problem started when i began using a new detergent from Tide called total care. Still tying to get the pump to work.
I have the same problem...How do you manually unlock the door so I can bail it out???
SOURCE: ND Error code
Error code "nd" means it is not draining. Click on this link to get the user manual:
http://laundry.manualsonline.com/manuals/mfg/maytag/mah24.html
Then click on "GET THIS MANUAL" to download the manual.
Not draining can be caused by the controller, pump, solenoid valve, or clogged drain.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
I have a Maytag MAH2400A Front Load Washer 2 years young now filled with water that won't drain during the drain cycle, and a door that won't unlock. is there a way for one to correct easily correct this?
My washer is the same model, same problem, what is this? What's wrong? I tried moving the drain hose around, manually draining it and restarting the cycle after unplugging and after flipping the breaker. Anyone?
I also switched to Tide toal care... my washer is 4 years old.
