Razor E100 Electric Scooter Logo
Posted on Jan 25, 2009
On an E 100 Razor scooter, the battery charger shows charged
Battery charger si showing charged but the scooter does not work, will nnot move
  • 2 more comments
  • Anonymous Feb 15, 2009
    i have a similar problem.I checked the charger output voltage and its fine.Checked the battery voltage and its fine,batteries OK.checked the thermal cutoff and its fine.I bypassed the control circuit and connected the motor directly to the battery and it runs fine,motor OK.There is no output voltage to the motor when selected on.handle bar switch works fine and can hear the relay working fine.tested the brake lever switch and it seems fine.
    I suspect that it may be the controller.costs about $20 and easy to change.
  • Anonymous Mar 18, 2009
    The battery won't hold charge longer than 5-10 min.
  • Anonymous Mar 24, 2014
    Can't I just to see if the batteries will charge take the charger Jack and clamp the wires on the bat and plug it in to see if it will charge? Pocket mod razor
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12369
Points
8
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12369
Points
How did you fix the transistor? Can you send me the schematics. dgarbaty at hot mail dot com.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12369
Points
Hi
I have a E100 thats not well.
The relay clicks when charging and Throttle is triggered.
The Brake circuit is tested.
When the Battery was charged to about 21 volts I tested the voltage to the motor and was ranging from 0.5 - 0.1 volts (this occurs when the scooter switch is on attempted kick start then check voltage when Throttle triggered)
I then wired the battery direct to the motor and nothing happened.
Any ideas whats wrong or what else I need to test?
thanks
is plugged in switched on and the bike is switched on. The Battery reads 27 volts. When I disconnect the The Batteries
linn brown
Level 1:
  • Contributor 40 Answers
  • Posted on Jan 31, 2009
linn brown
Contributor
Level 1:
Answers
40
Questions
Helped
35204
Points
69
Then it may not be the charger it may be the battery so have the battery checked. good luck1
Lisa Fletcher
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Apr 20, 2014
Lisa Fletcher
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12410
Points
I determined the E-500 razor to be a POS after the second one died. I found the EZip 500 to be substantially better in every respect. Well built, much more solid and lasted a long time. Buy through WalMart so you can get the extended warranty. The charger isn\'t charging the battery. They\'ve sent a replacement charger but it doesn\'t seem to have fixed the problem. I\'ll contact them tomorrow after putting in a new battery and trying again; but they\'re aware of the issue and will stick with it til it\'s fixed.
Anonymous
Level 1:
New Friend:
  • Posted on May 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
12369
Points
Pls send me battery charger circuit diagram used in bajaj scooter
Anonymous
Level 1:
  • Contributor 36 Answers
  • Posted on Jul 04, 2009
Anonymous
Contributor
Level 1:
Answers
36
Questions
Helped
27234
Points
70
If you hear the relay clicking, the controller is fine.
Either the charger isn't fully charging the batteries, or one of the batteries won't hold a charge and needs replacing. Check the voltage immediately after a charge, and after it stops working.
A pair of fully-charged batteries will read 26 volts or so. Even after 20 minutes of riding the voltage is still 24 volts. The controller contains a low-voltage-cutoff circuit - if the battery voltage falls too low (20 volts?) the motor will stop to avoid damage to it.
I got a non-working e100 from the junk, it had these problems:
- no battery charger - I used a cheap 12V charger from Canadian Tire, bared the wire between the two batteries, and charged the two batteries individually. I see a new one can be bought online for $20.
- one of the two batteries would not charge and only showed 10 volts. Replaced it with a 12V5AH for CAD$20
- the scooter still wouldn't work, no relay clicking - connecting the battery directly to the motor, it ran fine. Checked the control signals ("throttle" and brake - both microswitches) - both were fine. So the controller is not working.
- removed and checked the controller relay - it was fine. After figuring out the circuit I found a transistor Q2 was bad (it is part of the low-voltage circuit). If anybody wants the circuit diagram, send me a private message.
- now the motor worked, but no belt. Found one locally for $20 - I see them online now for $6 or so.
My son enjoyed the scooter for an hour or so, now there is another problem - it won't turn OFF! Must be the relay contacts stuck, or (unlikely) capacitor C1 shorted. Back to the soldering iron!
  • Anonymous Nov 06, 2009
    I unsoldered the relay from the circuit board and installed a generic 12-volt relay from my junk box - it's working well now
    Just found two more of the scooters by the side of the road with a 'free' sign on them ... batteries on order :)
  • Abdel Torres
    Abdel Torres Jan 28, 2014
    Hi im hoping you see this its been a while since you have posted about this.My questions is if i have a scooter wich displays battery full on the dadge and it displays the trottle reving, but only when the cable is plugged up. could it still be the battery ? My scooter is a 24 volt sitting scooter.It has been sitting for a year since ive had it.I just got charger for it .
I turn on my razor E300 the lights comes on to say its on but dont work i plug my charger in and on the chager the green light comes on saying its full charged what could b the prblem ?
The green light will come on if the charger does not sense a low battery. In other words, if you plug it into the wall, and not the scooter, it will still show the green light. It will only show a low charge (and charge the battery) if it is completely connected completing the circuit. My guess is that the battery is dead, and the plug is not all the way connected. Also, I believe the scooter has to be turned off to charge.
tip
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
Batterys showing full charge but when my daughter gets on in power kicks in then stops
razor hasnt been charged for a week as i needed a new charger i had 1 scooter charging over night yet still nothing , i bought a new charger its showing green on the light do i have to wait till it shows red and then wot if it doesnt still work
Razor electric scooter e 300 battery charges but won't run
first check to ensure the batter has held the charge you put into it. Just plugging the charger in does not mean the battery is holding the charge. If the battery is bad, it will drain as fast as you put it in. if the batter holds a charge, should be able to disconnect the charger and battery will show charge. if so, you have a bad connection or motor.
Jun 29, 2013 • Motorcycles
2helpful
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
2answers
Razor bella will not go?
one or both of the batteries must be bad, lift the seat up the remove the screws that hold the compartment down and then you should be able to see the two batteries below there, first visually inspect the batteries to see if they look like they are bulging, then test each battery with a multimeter and make sure it is showing at least 12 volts, chances are one or both of the batteries will not show more than 12 volts
E-100 razor scooter battery will not take charge
its dead they need to be recharged every time they have been used
6helpful
3answers
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
