Televison & Video Logo
Posted on Jan 26, 2009
Olevia 32 inch tv rca universal remote need a code to program
Lost remote for olevia,have a rca universal remote with no paperwork
need tv code and programing help
  • Anonymous Feb 22, 2009
    we have the same problem, olevia 32 inch with a rca remote. did you ever get a code for your remote?
  • Kholmesii May 11, 2009
    I need a four digit code for a olevia 32" tv I have the Rca NaviLight8 Remote which is model number rcr860 can any help me?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3190
Points
32 inch olevia tv code is needed for an emerson remote
gjoy
Level 1:
  • Contributor 3 Answers
  • Posted on Feb 15, 2009
gjoy
Contributor
Level 1:
Answers
Questions
0
Helped
21222
Points
6
Try using code 11610
Anonymous
Level 1:
Genius:
  • Contributor 1,199 Answers
  • Posted on Jan 26, 2009
Anonymous
Contributor
Level 1:
Genius:
Answers
1199
Questions
0
Helped
390839
Points
28
I have a rca rcu404 universal remote that I can't get to work for a 32 inch auria tv
Auria TV 5 Digit Remote Control Codes
11423
10017
11265
10178
10856
11178
Auria TV Codes for RCA 3 in 1 Universal Remote = 12087
ON MOST REMOTES (Generalized):
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
No one buys Universal Remotes, they are so 1990s :>D You buy a facsimile remote which is an exact copy of the original, no programming needed and all the original functions.
https://www.google.com/search?q=32+inch+auria+tv+replacement+remote+control
Your search query is 'make model replacement remote control'.
Can I program my RCA 4 in 1 remote control to the Olivia TV
Remote Control Codes For OLEVIA TVs - Universal Remote ...
www.directutor.com > content > remote-control-codes-...
Remote Control Codes For OLEVIA TVs and Instructions to program. Remote ... 3 - If your TV turned off then you entered the right code and setup is complete.
My Universal Remote ... - Olevia TV Universal Remote codes
myuniversalremotecodes.com > olevia-tv-universal-rem...
Nov. 13, 2019 - 5 Digits Universal Remote Codes For Olevia TV. 11144; 11610; 11331; 11858; 11240; 12272. Read down further to see the steps to program ...
How to program an RCA universal remote
ca.news.yahoo.com > quick-easy-guide-programming-r...
Oct. 3, 2019 - For example, if you want the remote to control your TV or Blu-ray player, hit and release the TV button or Blu-ray button. The remote's On/off button ...
2answers
What is the code for programming universal remote for philips 19 in tv model 19PFL3504D/F7
How To Program A Philips Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-philips-universal-remote/
Here is how to Program any Philips Universal Remote Control. Turn on the device you ... Remote Control Codes December 21, 2015 at 1:19 pm. Stephanie,
Codes For Universal Remotes ' Universal Remote Control ...
Universal Remote Control Codes For TV & Audio. ... Codes for Philips Universal Remotes · Sanyo TV Codes for Universal Remotes · Codes for .... I have an 19 inch Emerson flat screen and a RCA universal remote. Please help with the code ..
4answers
Lost a tv remote in a fire. Bought a universal remote but cannot fine a code to program it.
read the directions at the part where it says manually program, you have to do certian functions then push the channel up and down until tv responds then its programmed, this is actually finding the code as you go, instructions will explain it all because ech universal is just a little diff in its manual process.
6helpful
3answers
I need a remote for a soyo 32 inch tv or a code that works with a universal remote
The RCA RCR312wv sold at Wal-Mart for about 7 bucks has 2 SOYO codes and the second one worked on my 32" SOYO
2helpful
I need a remote code for a rca remote for the olevia remote control can you help
Unfortunately Olevia is one of those t.v. brands that is not compatible with many universal remote controls. They make a Universal Learning Remote specifically available from Olevia on their web site that may solve your problem if your universal remote control turns out not to be compatible with your Olevia television.
As for what codes you can try, there are many, and the codes depend on your universal remote control brand. Many times, an RCA code will work for Olevia televisions, so you should try the RCA codes that come with your universal remote first, before trying any of these other codes.
If you have a Dish Network Universal Remote you can use code 506 or 127.
Direct TV remote codes vary by model number on the remote control, but the following codes work with most Direct TV remotes: 506, 127, 11144, 11240, 11331, 11610
Cable Vision use code 506
Charter and Movie Box remotes you can use 1144 or 1178
Comcast codes are 11144, 11240, 11331, 21075, 10159, 10154, and 10088
Cox code is 1610
Brighthouse remote codes are 1610, 1144, 1240, and 1331
Time Warner remote codes are 1610, 1144, 1240, 1331, 432, and 1610
If none of these brands are what you are looking for as far as your Universal Remote Control is concerned, many universal remote controls will work with Olevia televisions if you use the codes found under the RCA, LG, Phillips, and Yamaha in the code listing included with your remote control.
12helpful
10answers
37helpful
14answers
29helpful
13answers
Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
