How do I change the walking belt on a Nordic Track EXP 2000?
First,
remove the motor hood. There are 3 screws at the front, and 2
underneath. The screws underneath will have to be removed by tipping the
treadmill over, or pulling the console towards the rear of the machine.
Next, remove the side rails. This is a little tricky because of
the cushion adjusters on each side of the deck. If you look underneath
the deck, you will see that the adjusters are on rails that are attached
to the platform. Remove all of the screws from the side rail and push
it toward the rear of the machine while also moving the adjusters
rearward. You'll have to kind of move them together until the adjuster
slides off the rail. Do both sides.
Remove the rear roller, by
loosening the bolts. Don't mess with the front roller unless you intend
to replace the motor belt. You don't need to remove the front roller or
the walking belt.
There are 4 bolts holding the deck to the
frame. The rear ones go through the frame to a lock nut. The front
bolts screw into the isolators. Remove them and the deck will come
loose. You can slide it out from the walking belt.
Place the new
deck next to the old, and start moving the parts over. Make sure the
safety decal is on the bottom like the old deck. All of the holes are
pre-drilled except for the belt guides. You'll have to measure for
these. Now do everything in reverse to reassemble the machine. I'm
also attaching instructions on how to adjust the belt.
First, ensure that it is the walking belt that is loose.
There is a belt hidden under the hood that connects the front roller to the
motor (motor/drive belt). Start the
treadmill at 3 or so and carefully apply pressure to the walking belt until it
slips/stops. Watch the front
roller. If it continues to spin when the
walking belt stops, it's the walking
belt. It the front roller stops with the
walking belt, the motor belt is
loose and needs adjusted or replaced.
To adjust the walking
belt, locate 2 hex head bolts, one on either side of the deck on the very back of
the machine. These bolts will be
recessed inside the plastic covers. Your
treadmill came with a tool for this,
but if you can't find it, a standard
(not metric) allen wrench kit will work.
It's helpful to have a wrench in each bolt so that you can adjust them
at the same time, but one will work.
The allen bolts
thread directly through each side of the rear roller. As you tighten the bolts, it pulls the rear roller away from the front
roller, tightening the walking
belt. This also centers it; if you
tighten one bolt, it pushes the belt
towards the center of the walking deck away from the bolt you're tightening. So if the belt is too far to the right, tighten the right bolt and it will move towards
the center.
Place your wrenches
in the roller bolts and turn the machine on to 3-4 miles an hour. Keep your fingers clear of the belt, it will eat them.
This method is quick, because
you can see the belt move as you tighten one side or the other. It takes a few seconds,
but if you tighten the right bolt for instance,
you will see the belt move to the left.
If the belt is loose but centered,
tighten each bolt ½ turn and then get on the machine and see if it slips. The user manual will tell you to pull it up a
couple of inches to test the tightness,
which is a relative method and doesn't necessarily work. My wife can pull on the belt and get 2 inches, and I can probably get 3 or even 4 if I'm showing
off. The best way to test it is to
gradually tighten it until you can run on it without it slipping.
You should lube the
belt a couple of times a year. You can get them from iconfitness.com
The above instructions is a generic one for this series. A slight adjustment might be required.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
The belt works for about 2 minutes then stops
