Hoover MaxExtract Deep Cleaner Logo
alice oquin Posted on Jan 20, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont pickup water
No suction max extract deep cleaner
Anonymous
Level 2:
New Friend:
  • Expert 91 Answers
  • Posted on Feb 13, 2013
Anonymous
Expert
Level 2:
New Friend:
Answers
91
Questions
Helped
36958
Points
203
Check dirty water tank make sure lid is on correctly and that the plunger is not stuck.
2 Related Answers
Anonymous
  • 240 Answers
  • Posted on Jan 28, 2011
SOURCE: i cant get the brushes
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Anonymous
  • 281 Answers
  • Posted on Apr 30, 2009
SOURCE: hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
1helpful
My Hoover Max extract dual v cleaner worked fine cleaning the carpet but when it came to using the hose attachment for my sofa, there was no suction and the brush did not spin.
Hello, Kathy -
If you have not yet checked your owner's manual; the Troubleshooting section, I suggest you do.
If you do not have the manual, you can download a PDF (Adobe Reader) version here:
https://www.manualslib.com/products/Hoover-Max-Extract-Dual-V-6126442.html
This is the link to the Troubleshooting section in the manual:
https://www.manualslib.com/manual/389163/Hoover-F7411900-Steamvac-Dual-V-Wide-Path-Deep-Carpet-Cleaner.html?page=19#manual
I hope you made sure the dirty water tank was empty and that the filter screen is clean.
Won't pickup water on rug
I may have already given my best advice but, check the hose line to the extraction tank and make sure there are no cracks in it. This will allow it to **** in air, and therefore reduce the vacuum pressure at the head of the machine, causing it to malfunction.
3helpful
Bissell pro heat will not extract water from the carpet
Try checking the top section of the machine (where the dial is located to switch it from floor to tool) and there is a little red plastic piece about 1 inch square on the inside of it. This is a lint filter that has a little door on it. Open the door or remove the entire thing to clean it out. It is probably completely blocked with hair, etc.. which is why you have no suction. Replace it after you clean it out and hopefully your problem will be solved!
My bissell proheat 2x wont vacuum up water
There is a float (usually looks like a red ball) that rises up if water is in danger of getting to the motor. Sometimes they stick.. Give it a poke to free it up.
All the best,
WD
Hoover steam cleaner wont pickup water
1helpful
Water comes out when trigger is squeeze but wont **** up dirty water
A. Is your floor/hose knob in the correct position?
B. Do you have suction at the hose end, when in that position?
C. If you answered yes, no in that order then either your motor (provides the suction) is going bad, or it simply is clogged and needs to be serviced.
MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ffuutr
It wont extract water
Something is probably clogging up the suction.
Try to snake it out with a coat hanger or similar tool.
Often, especially with shedding pets hair will clog the suction pipes.
Hope this is helpful.
Good Luck!
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
