Hi!
1. don't press the buttons like a hardcore boxer :)
2. disassemble the remote control. No big deal. It has a plastic housing the buttons are on a plastic/rubber sheet. (remove batteries first)
3. clean the plastic/rubber sheet where the buttons are both on top and rear side. Take some clean petrol from the groceries next corner, and clean the black pads on the bottom of the buttons + also on the circuit sheet you'll find inside the remote control.
4. Put everything together and...
find the correct code automatically.Turn on your device.
while pressing SET botton press POWER, and release them ,then press CH+,then release it
Then press POWER repeatedly untill your device responds.don't go too fast.
When it responds press ENTER to store the code.
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control - 1. Press menu 2 times to get to system info page 2. In the system
info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that
says IR and indicates you the channel your remote control one is
configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds. 2. then press the '1' button on the numeric pad of your dish remote 3. then press the '#' button on the numeric pad of the dish remote 4. then press the 'record' button (red dot button - stores setting) 5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Hello. I also had this problem and the solution is very simple.
Haha, just press the i+/? button somewhere on your remote.
I hope this fixed your problem!
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
The Sony RMT-833 remote is for a Sony Camcorder - see http://www.replacementremotes.com/store/images/RMT833.jpg
I think you mean the RM 833 remote - if so try eBay as listings there suggest it works with Number: RM-833 Compatible with TV Models:KVX250,
KVX2501D Hope this helps
it is one of these code you will have to try them all till you get the right one they are 059 060 019 014 052 075
1 turn on tv to be prog
2 on remote hold down set
3 whilst holding set button press and release power button
4 release set button
5 press tv button on controll
6 using key pad key in code
7 press enter button
8point remote at telly
9 press power button c if it works
if not work start again but use next code keep going till you get it to work try this site as well http;//esupport.sony.com
