Scanner area failure
(1) Check the connectors of the Fixing Assembly. (J101, J1011, J552 and J702)
(2) Replace the Fixing Assembly.
(3) Replace the Engine Controller PCB...
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
SOURCE: i have an error code on my printer Error Code: E100 0000 .
uninstall the printer and install the new software of the printer and it will run rate me please
SOURCE: canon ir5070 i have an error code e100-00001 what does this mean
E100 code
Laser Shutter not opening
Possible mechanical failure or cracked/damaged Primary Fan Duct preventing the Laser Shutter from opening fully.
SOURCE: canon xerox gp200d machine problem-
there is problem with laser unit or IP board. u will require a technician for that.
