I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
Have you tried holding in the DRAIN/SPIN button in for three seconds to clear the lock condition? It's printed clearly on the control panel. If not, what have you attempted so far? Let me know, so I may give you better advice.
Worked great - helps to read the instructions printed on the actual panel - but I had to read your post first! Thanks
FYI after I used the tip above to get the panel unlocked on my mine, I took the lower panel off to figure out the draining problem. If you unscrew the large white cover (about 3'4" opens by hand) in the lower center you will get access to the pre-pump screen. BEWARE: you may get a bunch of water if yours is backed up. In there a found one baby sock and looking up the drain tube I found another. Now works good as new.
Did not work for me. what about unplugging it -- will it reset?
I have encountered the same problem and now I can use my washer again. Yay!!
Thank you.
THANK YOU! THANK YOU! THANK YOU!
I held the button down and it worked. I was so worried about a repair bill right before Christmas and all the clothes that needed to be washed. Thanks again, you have saved the day....
I have a whirpool Duet Electric Dryer - "control Locked" light is lit. Normal procedure to hold down the "end of cycel signal" button for 3 seconds does not work
I recall a couple of buttons that could be held down to reset?
help?
On a Kenmore Elite HE3 Dryer, the 'Control Locked' light came on today
and will not go out. I have tried holding down the Auto Dry Level
button for 3 seconds (many seconds, actually), as well as the
Pause/Cancel button and also unplugged the unit for about 45
minutes. No luck so far. Any further suggestions?
On my Kenmore Elite HE3 Dryer, the 'Control Locked' light came on today and will not go out. I have tried holding down the Auto Dry Level button for 3 seconds (many seconds, actually), as well as the Pause/Cancel button, and the Start button and also unplugged the unit for about 45 minutes. No luck so far. Any further suggestions?
Washer is HE3 front loader, Light on Control Locked. Unplugged, no other buttons work if pushed. Door does open, unsure what to do. mj
