LG L1730S 17" LCD Monitor Logo
Posted on Jan 21, 2013
My monitor is showing lines - LG L1730S 17" LCD Monitor
Getting vertical line in acer monitor
Apparently it is a display hardware problem. Try another monitor with the same cable and video card. Then you should try another cable. Then another video card. If vertical line doesn't show in either case, then you should replace the appropriate device\cable. If it shows anyway, then bring your monitor to service center for diagnosis.
1helpful
My hp pavilion dv600 freezes then lines show up help?
Try this: see if you can find an external monitor, use a VGA cable to hook to monitor...tell me if the lines are still showing on the external monitor...
let me know.
LGM578RIO1OOGRNAO-TO2, have this box with the letters showing at
There should be buttons on the monitor that will help you with menu issues if you don;t have a remote for it.
You also might want to Google the correct monitor,, as the one that you posted does not exist.
Compaq presario show straight line in middle of monitor
That happens only when there are loose connections and/or a problem like you dropped the PC or hit it hard. It MAY be because of moisture.
I guess you need to show it to an authorised HP doctor.
Samsung Monitor 2232BW
consult a technician you could not do any thing for this fault
Havea lot of lines on monitor
theres a adjustment on flyback they have two adjustment screen.if you made an anjustment turn off the monitor the adjustment anti clockwise little bit.
by the way my name is robert im technician all branded name of sony, jvc,philips etc....
Samsung Monitor Syncmaster 913V Montior Screen shows patches of screen on desktop and playing videos
Sounds like your LCD panel has gone bad.
If the unit is under warranty, take it to a Samsung repair shop. If it is not under warranty, go buy a new one. LCD panels are usually more expensive then buying a whole new monitor.
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
