With the mentioned printer I used A5 Paper size in Tray1 & A4 paper size for Tray2 .... My problem with tray1 only every time I print from tray1 with A5 size I getting the 13.02.00 error code. Recently I have replaced Tray1 Pickup Roller & Tray1 separation pad but I facing similer issue. When A5 paper feed printer feed 2 sheets one will stop at Ejection Fuser roller & the other one it will jam at the bottom of Toner Cartridge. I did paper path test from Tray1 with " A4 paper " after cleaning printer from dust with 100 pages it's printing fine without any issue, then directly I did Paper Path Test from Tray1 with " A5 paper " then I face same issue. Please help. Thanks. Jaffar
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
SOURCE: I have a HP CP2025
It sounds like a blockage in the paper path at the rear of the unit. This unit picks from the rear of tray 2, and there is a separate path for tray 1 that conveys the paper above that tray and back to where it can intersect the main paper path. Sounds like you have a blockage where those 2 paths intersect.
Remove the cassette 2, and in that hole, there are 2 levers that allow you to lower the bottom half of the tray 1 bypass path. Look back in there for the tiniest scrap of paper left behind.
Next, if nothing is found, open the rear door, and again with a flashlight, look down in the bottom of the paper path for a small bit of torn paper, or some other obstruction. Odds are this is your problem.
SOURCE: A HP Color Laserjet 3000n has the following errors
Perry,
Usually I have found that there is a scrunched up piece or bit of paper in the fuser.
I am adding a link below that will take you through the step-by-step process and you should find the source of the problem. Be careful when touching the fuser that thing gets HOT!!
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00506722
Please let me know if this has helped and if i can help you any further.
Thanks
you have to check the paper you use is it the same format in the printer setup.
http://www.smoothprinterservice.com
