Looks like a pair of shorts stuck between drum and the gap between door and drum machine wont do anythink just flashes e90 and the door wont open
You will need to remove the drum and reset the alignment.
The cloth is struck and has jammed on the drum movement.
click this link: drum removal
I can't afford a tech to come out and fix my washer I need help to open the door or just start my washer please it's about a 2008 to 2010 model front loader electrolux
SOURCE: i have a electrolux front
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer
