Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker Issues-only crushed ice works, cubed comes out crushed
Even when I set my GE sided by side to cubed ice, it is still constantly crushing it. When I set it to crush ice, it crushes it. No matter what I do, it will not dispense cubed ice.
Also, when we have the icemaker on, ice is forming in blocks where it looks like it falls down. I don't know if I have the temperature too high or too low (have both fridge/freezer set to 5). It dosn't look like it drops individual cubes, more like a massive rock of 15-20 cubes...
I had the heating coil replaced at the bottom of the freezer about 3 months ago...other than the cubed ice and ice maker slightly malfunctioning, everything works fine.
Thanks in advance for any good advice.
  • cramercl Feb 11, 2009
    Tested the dispenser as described revealing a bad solenoid. Any suggestions on part #'s or where to find?
  • 65 Answers
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Mine was doing the same thing. The solenoid that lifts the metal rod was stuck on the crush mode. I determined this by opening the door and holding the light button down with my finger. I pushed the dispenser lever on both crush and cube mode and the solenoid would not move. I manually pushed it down with my finger and it was freed up. I tested it again by doing the same thing with door open.m the solenoid would now switch. Works like new again.
Posted on Sep 08, 2012
    New Friend:
I have had this same problem on my side by side GE fridge. Followed the "trouble shooting" RESCUEDRIVER1 provided and none of those were the problem on my machine...(Although I was glad I had these extra tips to check first). I found that after emptying the entire ice tray and rotating the "crusher" drive of all misc. pieces was the problem. When the ice tray makes more ice, HOLD DOWN the "cubed" key on the outside and dispense until it produces only whole cubes! (YEAH!) Hopefully this will work for you, as it did for me.. good luck!
Posted on Jan 03, 2010
    New Friend:
OK. This may have only been a temporary fix, but I simply pushed down on the thingy that is in the window that is to the lower left of the ice dispensing auger which was revealed after removing the ice bucket. Now I've got cubes!!!
I never want crushed ice, so this may last.
This was done on the GE Profile PSC23SD, btw.
Posted on Mar 25, 2014
    New Friend:
Carl Schulzetenberg's suggestion worked for me. Thanks Carl...
Posted on Feb 03, 2013
    New Friend:
Read all the solutions to "fix" my GE ice-maker and nothing worked ......... until, I unscrewed the 4 screws in the ice bin (2 on either side) and saw that the long metal rod was not snapped in the center guide. I pushed it into the guide and guess what??? I now have cubes after 3 years!!!!! Whew - who knew it could be that easy! Thank you all for forcing me to check every possible solution w/o having to call a repairman.
Posted on May 03, 2012
    New Friend:
My ice maker was only dispensing crushed ice. My spring on the rod under the ice tray was a loose from the rod that is under the ice tray, after I hooked it back to the rod my ice maker begin to dispense cube ice instead of crushed ice.
Posted on Oct 28, 2011
Anonymous
SOURCE:
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
Posted on May 23, 2009
Anonymous
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: can not get cubes from the front, just crushed ice and water?
Hi
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
woodchuck789
Charles T Nevin
  • 4070 Answers
SOURCE: icemaker is on cube but is still crushing ice it
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Posted on Nov 13, 2009
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | GE Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Dispenses crushed ice instead of cube ice
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker dispenses crushed ice in the cube setting. Water and crushed ice are fine.
Typical of a switch failure / control module failure so it sticks on the crushed ice setting or the crushing mechanism is u/s and wont turn off. Call a service engineer asap.
Aug 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My icemaker, a ge profile is only making crushed ice, no cubes,
There is a selector for crushed or cube and is usually at the dispensor.or above it. good luck
May 26, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice crusher has stopped crushing
Replace the switch behind the front panel on the freezer.
Mar 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Dispensing problems
Check that the crush mechanism is not jammed with ice. That could prevent it from disengaging.
Dec 31, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice Maker will not dispense ice cubes only crushed ice
sounds like the circuitry on your Cubed Ice button has malfunctioned. Contact the manfacuturer for a solution.
in the meantime, u can grab the Cubed ice manually.
hope this helps!
Jun 16, 2008 | Frigidaire FRS26R4A Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
9,132 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Ron Beer
Ron Beer
Level 1 Expert
Vish Iyer
Vish Iyer
