Dewalt 18v Battery Hammer Drill Dcd950 Dc925 Logo
Posted on Jan 21, 2013
MY DRILL GOT STUCK - Dewalt 18v Battery Hammer Drill Dcd950 Dc925
Level 1:
Habit-Forming:
New Friend:
  • Contributor 41 Answers
  • Posted on Jan 24, 2014
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
41
Questions
0
Helped
35315
Points
42
If it does not go around and it goes around when you help it in the beggining this means that the rotor of the motor is broken
Stuck drill bit in black and decker 18v cordless drill
Lock the chuck and undo the collar. Lock is midway between Screw and Unscrew.
Or if it is stuck because the drill was really too big, put the drill on the floor and hold it with your foot, grip the drill with channel lock pliers and hit the jaws with a hammer away from the drill.
How to remove bit it's stuck and not moving
Drill bit? If it's stuck in a piece of metal try drilling from the other side and then knock it out use a maller drill bit.
Stuck in metal, use vise grips to grab it and turn counter clockwise
Stuck in drill chuck? Get a key for the electric drill. Battery operated, use a par of pair of channel lock pliers to open the chuck.
Ryobi 18v drill stuck chuck
easy to fix
with the drill not running
grab the bottom part of the spinning part of the drill nearest the drill's motor.
then
grab the spinning shaft bit nearest the drill bit
pull them apart slightly
when the two parts are pushed together thay lock the chuck
I own a ryobi hammer drill that does the same thing
I have a drill bit stuck in the head. I put the bit straight in and now its stuck. Is there anyway to take it out?
Grab the drill head as hard as you can put the drill on drill setting and the highest number setting and put it reverse
Bit stuck in drill
OK, try to grab the chuck tightener and loosen by pressing lightly on the drill throttle button in whichever direction it takes to undo the stuck in drill bit.
I do this all the time.
2answers
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
I have an 18 volt hammer drill combo drill. I
Do the same in reverse, if possible. Also, you could use two channel locks as most of those chucks have two rings, the narrow one towards the drill itself being attached to the motor. However, make sure the screw inside the chuck is tight first -- I've seen those back out and block chucks open.
3helpful
Drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Dec 02, 2008 • Drills
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
