Kyocera RI-3530 Black and White Copier Logo
A
Anonymous Posted on Jan 21, 2013
MY KYOCERA KM-3530 DISPLAYS ERROR CODE C6000
5 Related Answers
Anonymous
  • 74 Answers
  • Posted on Mar 27, 2010
SOURCE: Morning,
1650 machine is a medium size machine for small offices and home users. The machine is equipped with a self diagnostic function so it displays an error code whenever its processor detects a problem during copy process.
Some codes can be reset by simply opening and closing the front door or by turning the machin on and off, but there are some others that can be reset only by a service representative. C 6000 code is one of them. There are several causes that lead to this problem, i;e:
1. Unstable power source
2. Low volatage
3. Broken thermisted wire
4. Poor contact in the thermister connector terminals.
5. Heater lamps are broken or not installed correctly.
Here is the process to reset c 6000.
Enter 1087-1087 (1087 twice) from the keypad.
U000 will be displayed.
Enter 163 by using the keypad keys.
Press "Start" (the green button) twice.
The code will be reset and machine will start automatically.
If this code is appeared again, you may need to check the fusing section of the machine and it shoud be done only by a service engineer.
Anonymous
  • 43 Answers
  • Posted on Mar 02, 2008
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Henry Gertcher
  • 48 Answers
  • Posted on May 26, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
Anonymous
  • Posted on May 11, 2010
SOURCE: Kyocera Mita KM-C3232- Error Code C6000
The power source board may have created this problem and replacing the fuser may only be a temporary fix and after replacing the power source you may to replace the fuser again.
Anonymous
  • 713 Answers
  • Posted on Feb 15, 2011
SOURCE: error c6000 kyocera km-2560
THERES A PRINTER OR A PAPPER JAM GET AIR IN CAN BLOW OUT IF CARDLIDGE REPLACE WITH NEW.
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
2answers
KEOCERA MITA photocopier KM4035 have problem. My Machine is showing error code C6000. How to tackle this proble. Please help me as soon as possible.
KM/CS 2530, 3530, 4030, 3035, 4035, 5035
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Press EXCUTE on the touch panel. It is displayed in reverse.
Press "Start / Print key.
The machine will turn off and then back on then come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
2helpful
Morning, my copier machine is the type of kyocera mita km-1650 then if i switch on it gives me error of call service c6000,Please can you help me?
2. Low volatage
42helpful
3answers
3helpful
Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
7helpful
2answers
Henry
2helpful
2answers
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
55helpful
3answers
Have error: C6000 on Kyocera KM-3050
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
11helpful
3answers
Copier giving error
Defective Optical Laser Unit or main board. Is it making noise?
If so, it is the laser unit.
And that is more likely than the main board.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
