Latch is broken off and I want to know if I can buy the part and replace my self?
SOURCE: FWT449GFS1 front door buzzing Frigidaire front loading washer
Could be rubber door boot needs replacing. I am in the midst of replacing mine because door won't stay closed and buzzer sounds till I hold in door.
scott
newcastle on.
SOURCE: GE front load washer WSXH208v1ww door latch
Unfortunately, the "door latch assembly" is what you would need. It comes with a new concrete front tub counter weight which is redesigned to not be able to contact the door latch switch on out of balance spins. It is also a lot of work to replace. (you can not get just the little plastic part) Please don't rate this solution, as anything but a Fix-Ya lowers my score, and I know you don't want to shoot the messenger.
SOURCE: Broken door latch
Why do you want to fish it out, the door might malfunction. I suggest you change the door lock mechansim, can do it your self.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
SOURCE: lg wd-8013c washer door latch broken. Is there an
Run a shoelace between the door and the face of the washing machine, starting at the top, over the latch on the middle of the right hand side and down to the bottom.
Pull both ends of the shoelace towards the hinge on the left.
This pulls open the latch with NO DAMAGE and allows access to the screws that remove the latch mechanism. Easily ordered and installed with two screws and a plug to reattach.
LG give no support or reference to this easy procedure in their manual. SHAME!
SOURCE: Kenmore washer HE3 broken door latch. How do you
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
