Kenmore 43142 Front Load Washer Logo
Johnny Hunter Posted on Jul 20, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 417. 4405200 Front Load Washer error code E43
I?m stuck, and desperately need help. The washer completes wash cycles, but never spins. After performing the diagnostic test from the washer tech data sheet, I get error code E43 (Control Board problem) the washer does spin in the diagnostic test. I ordered a new control board, replaced it, same result. I then ordered the speed control board, same result. I have performed a continuity check on every wire in the washer, both vacuum tubes are clear; the pump is clear and pumps the water out. One of the Shock Absorber, air, stabilizers is broken (on back order until the end of the month) should be here the 31st. Any ideas ???? Thanks in advance De_fender
  • 1 more comment
  • Johnny Hunter Jul 21, 2007
    No, the washer was not loaded when I preformed the diagnostic. however I have been washing cloths and then using the last step of the diagnostic test to spin the cloths out.
    de_fender
  • Anonymous Feb 21, 2008
    I have the EXACT same problem and I feel like rising up in revolt against Sears Canada. I bought this machine in good faith - and I'm incredibly frustrated.
  • Anonymous Mar 28, 2009
    same problem no spin. fault 43 and 1 broke shock.
Chris Goulet
Level 2:
  • Expert 41 Answers
  • Posted on May 14, 2009
Chris Goulet
Expert
Level 2:
Answers
41
Questions
0
Helped
177309
Points
119
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
  • Chris Goulet Jul 25, 2009
    If your bad wax motor is a 0.05A rating, replace it with a 99001807. It should measure about 1.5K ohms.
    If your bad wax motor is a 0.12A rating, replace it with a 12002535. It should measure about 1.0K ohms.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
2383
Points
For me was door lock switch. glad i didn't listen to trouble shooting chart that came with washer, code 43=control board. was going to try speed contol board till i read de fenders story. now i have big @#$%^&* pile of wash to do.
Anonymous
Level 3:
  • Master 641 Answers
  • Posted on Jul 20, 2007
Anonymous
Master
Level 3:
Answers
641
Questions
Helped
957887
Points
1616
Does the washer was loaded when you make the diagnnostic test ?
Anonymous
Level 1:
  • Posted on Aug 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2383
Points
Same problem here too. My washer is only 18 months old. I have only gotten so far as to get the error code, which is a 43.
Should I go through the Diagostic test and see if the machine spins?
I am a total amateur here, but I refuse to pay a repair person to come out for an 18 month old washer. Ugh.
  • Anonymous Aug 18, 2009
    Does anyone have the part # for the door lock switch? Should it cost around $50???
Kenmore Front Load Washer won't complete cycle F06
Have you cleaned your machine lately? They make an in wash boost- it gets rid of the extra suds built up inside the machine that you cant see but your machine detects it and causes faults such as that. Also, there is a small wire on the control board that may need replaced if it keeps kicking the error code.
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
How to reset an error code e43 on a frigidaire affinity front load washer
Hii Michael, Search online for "error code e43 reset". You should get a hit on justanswer.com. Follow that link, it looks promising.
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
2answers
Kenmore 44052 will not spin. Replaced door switch still will not spin. Ran diagnostics (code E43) so I replaced motor control board still will not spin. Could not get out of diagnostics so I replaced...
Have you pulled the pump and checked for obstructions? There may be something in the pump itself; you will need to check that...
If your problem can't solve, keep in mind that the error codes means physical wrongs, so, E43 is a door-locking problem or "board comunication problems".
I hope this helps.
Kenmore HE3 washer emits steady, constant beeeeeeeeeeeeeep
Depending on how your washer controls the beeper, it could be a stuck relay or a fried transistor.
417.4405200 not spinning at the end of wash cycles
Alexander
vince
