Does anyone know where i can download a user manual for this washer??
SOURCE: User Manual required (Kelvinator Washing Machine)
Click on Bosch or your brand (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
SOURCE: Bosch logixx 1600 workshop manual
Look for user manuals at http://www.user-manual-search.com
SOURCE: beko AA class washing machine 1000rpm WMA 510W
you put it on a 40 degree on the other side on the top left hand side i had the same problem for ages i couldnt help but laugh when i seen this
SOURCE: how to change brushes on beko washing machine
remove rear cover of washer, locate and remove belt.
Unfasten motor ,disconnet motor lead, and remove motor.
Brushes are located at opp end to motor pulley.
Replace if less than 5mm long.
Plz rate my solution.
Thanks
SOURCE: beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
