After owning the system for 6+ years now, i just stopped working. It is connected to my PC and LCD-TV on 5.1 input channel. I was listening to music, when I heard a 'strong click' (may be spark) sound (most likely inside the reciever) and there was no more suound from speakers.
I will explain further here the situation.
There is display as normal on the reciever. I can select different inputs from function knob...but no sound on any channel.
There is no sound in speakers, but subwoofer has sound, I can feel that by raising the volume.
Is it a something which can be reset? or fuse ? protection mode?
thanks for reply
There are 4 blue relays in the unit that has solder points that will crack over time.
It´s fairly "easy" to re-solder them and viola, it´s OK again.
open the cover (unscrew and take of the hood) and locate the 4 blue relays.
Unscrew and remove the bottom service plate and locate the soldering points for the 4 relays.
Each relay has 6 solderings, 4 in one "groop" and 2 in one "groop" look especially at the "2-groop" these are the ones most likely to crack over time ( fSTR-DB840 no sound in speakers - 3436d08.jpgars or so).
Re- solder. Best of luck //Ronnie Stockholm
Definitely saved my STR-DB840 - purchased open box from C-field outlet June 2001. Got both A and B channels back.
Now just got to see how long the relays themselves will last...
I did the same and all is good now(2019 and still working), thank you
Here are the 4 relays in "2-groop" location in pcb image, just in case
Could you please re post the pictures Seem that they ;re removed somehow....Thank you in advance
See picture :
Un grand merci pour ce conseil !
Ca a fonctionn? pour moi.
Attention, il ne suffit pas de "recharger" en soudure.
Il faut d'abord ?liminer la soudure avec une pompe ? dessouder, puis refaire les soudures.
Je joins une photo avec les soudures clairement identifi?es.
A noter les rep?res pr?sents sur le circuit imprim?, D545, D546, D649, D749
unit is wired correctly and functioning aside from sound coming from speakers. Speakers are fully functional and correctly connected
