? 3:57 https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
1 The washing machine door handle may have broken. ... 3 The electronic door lock called an interlock ...
? 1:30 https://www.youtube.com/watch?v=gSF4JS2B_U0
Feb 25, 2012 - Uploaded by ScottStorm1
How to open a locked washing machine door when the handle / catch is ... How to fix a washing machine door ...
if your appliances all blew they may have been fuse protected, such as tv's and microwave have inside them. Power converter should be fuse protected as well. If the plug was wired incorrectly was it a fifty amp service or thirty? Does your power run threw a transfer switch? look there as well. typically voltage spikes threw ground circuits take out your electronics. Using ground fault interruption circuits and voltage protectors in between your plug and power supply will prevent most/some damage. many variables to pinpoint without input.
There actually aren`t anything different about most rv appliances, with the exception of gas/absorbtion fridges. As far as the "Splendid" brand washer/dryer combo, they are just an "equator/bendix" with a different badge and a little more compact...harder for me to work on is all, no elbow room, hah ha !
The water inlet lines, power cord, and drain are all the same. ( unless someone has changed them ).
Hope this answer`s your question. If you are satisfied with this solution please rate it accordingly. Thank you for visiting "fixya" and good luck.
if you look at where the handle is while pulling the door slightly towards you you may be able to see the door leaver get a piece of wire make a hook and pull on it if this does not work you will have to take the top off and do it from there also check near your filter cover if you have one some washers have a release wire good luck let me know how you went
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Depends what you mean by the "handle". The outer door ring is listed as a spare part 112100592, and behind it is the "handle"
112300530.
In view of the age of this model, spares may be hard to find, so keep an eye on eBay for a used door or door assembly or whichever of the part numbers above is required. Good luck.
I FOUND MY OWNERS MANUAL FOR THE W/D AND THE NUMBER IN THE BACK. WAS $40 PLUS $12 SHIPPING... 3 DAY DELIVERY.
THANKS.
I need a drive belt for a splendide wc2100xc
