I need to reset it out of protect mode and it says press the reset button but there is none not even on the graphic in the manual that labels all the buttons
Pressing reset button on Kenwood KDC 200u didn't help to fix problem with it it still keeps showing "Protect" on displayPressing reset button on Kenwood KDC 200u didn't help to fix problem with it it still keeps showing "Protect" on display
You can't post conmments that contain an email address.
PDF
Clock display (KDC-139) ... demonstration. KDC-139. Display. Setting Setting overview. Source. "CLCK". Refer to page 11 ... you have to start over from step 4.
Try checking your speakers and speaker wires for shorts and/or grounds. If your speakers and speaker wires check out, you may have a bad internal output ic.
A speaker wire has a short-circuit, crossed, or touches the chassis of the vehicle it activates the protection mode function.
? Wire or insulate the speaker cable properly and press the reset button. If the "PROTECT" code does not disappear, consult your nearest service center.
I have attached a link for you which is for a free Kenwood KDC-MP443U instruction manual download. Nice receiver by the way! Kenwood KDC MP443U Instruction Manual
The unit goes on protected mode when an internal fault is detected.
Try disconnecting the battery cable for five minutes . If there is no fault you will clear protected mode.
If the unit still goes on protect, then check the wiring at the back, a short in there can trigger protectedd mode. If that does not work, then there is an internal fault. In that case the unit must be disassembled and tested.
try checking you speakers and speaker wires for shorts or grounds. if they check good try pressing the reset switch. if none of these work, you probably have a bad output ic.
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
