HP Photosmart R827 Digital Camera Logo
Posted on Jan 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP Camera won't flash
My photosmart is only 2 years old, hardly ever used and always sits on my desk in a charging dock. Now it will not flash, only saying "flash charging".
A friend suggested that by never letting the battery drain it may not hold enough charge to flash and a new battery might fix it. I bought one and it did not change anything. Everything else works and I can take a photo in outdoor lighting without a flash.
BTW... when I called Hewlett Packard tech dept., I was connected to India and was told I could trade this in and buy another......fat chance of that...EVER! ...Hewlett Packard will never get another dime from this customer
  • greersantiqu Jan 28, 2009
    Thank you for taking the time to write. I am hoping to hear more opinions if there are any out there. I used this camera infrequently but I did use it primarily with a flash indoors. It also cost almost $400.00 as a package 2 years ago and hoped that this can be repaired reasonably.
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Jan 28, 2009
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1027627
Points
5636
HP wont get your money for another camera period- the have dropped cameras from their line up- in the UK any way.
The precise reason for the non function of the flash is not immediately fathomable - but it is likely non use ,the capacitor that triggers the flash in a full state and not having been discharged could have 'killed' it.
As with pretty well all low end digital camera s'repair' is not an option, only replace.
So off you go and buy a new one- if it is flash you need- but perhaps you can live without it.
So often you see folk using their camera swith the flash popping off when in fact non was needed.
1helpful
Cannot upload pictures from HP Photosmart 620
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
How do u charge the camera? What does the charger look like?
You can charge the batteries in three ways
1. Using an AC power adapter. Connect the AC power adapter to the camera trough the power adapter connector below the usb connector on the right side of the camera (looking from front). Then connect it to the AC power outlet.
2. If you have an optional HP Photosmart camera dock, plug the camera in the dock and then dock the camera. Same thing if you have a wireless dock.
While the battery is charging, the battery charging light in the camera blinks. Once the battery is fully charged, the blinking light stays solid.
It is better that you read the user manual for the camera. If you dont have one, download it free from the web: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
The charging procedure is given with figures on page 6.
I put a new battery in my camera charged it. Used the camera till the battery ran down. Now it won't charge . This is the second battery I've bought every time I try to charge it won't charge.
It takes over 7 hours to charge, so did you leave it charge overnight?
But while the original battery is chargable, disposable replacements are not. Here is what the manual says:
The supplied battery is a Li-ion battery. It charges while in the camera using the supplied charger. The camera can also use a Duracell CP1 disposable Li battery, which has the same form factor as the supplied Li-ion cell. HP claim the Li-ion cell will provide power for approximately 200 shots under "average" use and 100 shots with "extensive use of the LCD and flash".
Charge time for the battery using the supplied charger and in-camera charging is 5-7 hrs for a fully depleted battery. In the optional docking station, charging takes 2.5-3.5 hrs and using the optional rapid charger, charging takes 1-2 hrs. ... }
http://www.bobatkins.com/photography/digital/hp707.html
1helpful
Camera won't charge on dock
usually this happens to old cameras and other devices. is your camera old?
1helpful
Hp photosmart 720
My Photosmart 720 has also just stopped working. It simply won't turn on, with battery or mains power. So I took it to pieces. Inside is a thumbnail battery, labelled "5.5v 0.33f" which tests out at 3.0v DC. I surmise that the purpose of this battery is to remember the settings when the main batteries run out - but it could conceivably have some other purpose, like helping it to boot. Whatever the reason, it has clearly run down and I would guess that the other people on this list have hit exactly the same problem.
If I'm right, and the camera depends upon this very-hard-to-access battery, it is shocking that HP could get away with selling a camera designed like this. It implies that the camera was cynically designed with the expectation that it would be thrown away after (I would guess) five years. How's that for built-in obsolescence ? It *may* be possible to remove and replace this battery without damaging the camera, but there certainly isn't a manual that tells you how... is there ?
Hp 945 frosen with red light on
I posted on July 16 with this flashing problem and played around and got mine working again.
Originally I would charge through the docking port. What I did was pull the charged rechargable batteries out of the camera and took the charging cable from the docking station and pluged it directly into the port on the side of the camera. The camera started working again. Then while the charging cable was pluged into the camera, I reinstalled the rechargable batteries. After installing the batteries I unpluged the charging cable and the camera still works. I have shot and downloaded from the camera pictures with no more problems. Use the docking for downloading pictures and the side port on the camera for recharging the batteries.
I do not know if this has anything to do with the original problem but I did not have any problems with this camera until I placed it on the docking station with non-rechargible batteries.
Hope this helps.
BROBLEM TURNS OFF
I know this sounds like a no-brainer, but do you have the battery installed in the camera? Also, plug the camera into the charger until it is completely charged. It is completely charged when the blue LED on the dock stops flashing. Or, if you are charging it by AC adapter, just keep it plugged until the blue LED on the camera stops flashing.
3helpful
4answers
HP R927 Camera
I had this problem with my camera after a year. Scratching the battery contact terminal inside the camera fixed it.
Why won’t my camera recharge my batteries?
Not all cameras can charge batteries. CAUTION: Rechargeable batteries must never be used in the HP Photosmart 210 and 215 series digital cameras. The overload protection and control circuits are not designed to handle the kind of power intensity delivered by rechargeable batteries. If the camera is a model that does charge batteries, ensure the batteries are rechargeable: The only acceptable rechargeable batteries for HP Photosmart cameras are NiMH cells. Neither lithium nor alkaline cells are rechargeable, and they will not be charged in the camera. The camera must detect the type and condition of the batteries The camera will only charge batteries when it detects the batteries are rechargeable and in good condition. New rechargeable batteries, and/or batteries than have been unused for a long time will not be recognized as good batteries. If the camera fails to charge NiMH batteries, charge them in an external charger once, then use them in the camera. If this does not correct the problem, the cells are old and/or damaged and new cells must be purchased.
Top HP Cameras Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Are you a HP Camera Expert? Answer questions, earn points and help others
