https://engefood.com.br > ...
PDF
Pacojet Junior Service Manual. Current version: 18.12.2017. Page 46. Appendix. 1 Spare parts list. Pacojet PJJ. Spare parts list.
I wouldn't suggest buying such recovery CDs from 3rd parties when you have the option to get it from Original manufacturer. Buying it from a third party will not guarantee desired results and you may lose a lot of money. You can get it through the official Panasonic website. Here's the link: Panasonic Mobile Computing DVD Requests
Press SHIFT [MATRIX], specify the matrix to be inverted, then x^-1.
Example #103 in the appendix shows the exact procedure for inverting the matrix entered in example #096. If you need the manual and the appendix, you can download them from http://support.casio.com/manualfile.php?rgn=1&cid=004001004
BULLETIN NUMBER: J001/J003/J006/J007/J010/J011 – 021 07/02/2008
APPLICABLE MODEL:
GESTETNER – GX3000/GX3050n/GX5050n
LANIER – GX3000/GX3050n/GX5050n
RICOH – GX3000/GX3050n/GX5050n
SAVIN – GX3000/GX3050n/GX5050n
SUBJECT: SC999 OCCURS
SYMPTOM:
An SC999 (Maintenance Stepper Motor Home Position Error) occurs.
CAUSE:
Some of the ink in the machine has dried, and as a result the maintenance stopper motor cannot rotate or
the levers come loose.
NOTE: The following conditions make it easy for the ink to dry up (See Appendix 3 for more details):
- Low humidity
- Long intervals between machine usage
- Total period of usage is long
- Low Print Volume
COPY QUALITY
Fixed ink Stepper Motor
Right Flushing Gate
Levers
Tech Service Bulletin No. J001/J003/J006/J007/J010/J011 – 021
Page 2 of 5
SOLUTION:
Production Countermeasure:
The shapes of some parts in the Maintenance Unit have been changed in two steps ("Step 1" and "Step 2"
below).
NOTE:
See Appendix 1 for the details of the Step 1 and Step 2 modifications.
See Appendix 2 for the visual differences among the unmodified unit, the Step 1-modified unit, and
Step 2-modified unit.
See UNITS AFFECTED for the Serial Number cut-in of Steps 1 and 2.
Field Countermeasure:
1. Cycle power OFF/ON.
2. Install one of the modified Maintenance Units ("Step 1" or "Step 2").
NOTE: For customers experiencing a SC999, have them contact 1-800 Ricoh38 for replacement.
Hello, Here is the solution for th FX-991ES. Hello,
The error may be due to the key you used to signifie
inverse. It says in the manual that you should use the key x^-1 not the
one used to input general powers. Here is screen capture from the
Appendix to the manual. The picture shows the sequence of keys to press
to obtain the inverse of a 2x2 matrix. It is taken from page 41 of
Appendix
The matrix used in the exemple is a_11=2 a_12=1 a_21=1 a_22=2 Here is the link to download the manual and the appendix
The error may be due to the key you used to signifie inverse. It says in the manual that you should use the key x^-1 not the one used to input general powers. Here is screen capture from the Appendix to the manual. The picture shows the sequence of keys to press to obtain the inverse of a 2x2 matrix. It is taken from page 41 of Appendix
