Canon MultiPASS MP730 All-In-One InkJet Printer Logo
Rosemary Bourne Posted on Jan 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't copy at all and printing only shows up color; no black.
Moved printer from home office to work office.
Refresh Cartridges
Level 2:
Sergeant:
  • Expert 241 Answers
  • Posted on Jan 23, 2013
Refresh Cartridges
Expert
Level 2:
Sergeant:
Answers
241
Questions
0
Helped
75373
Points
609
Sounds as if the black portion of the printhead may have become dried. I would recommend running1-3 cleaning cycles in an attempt to pull through more ink. If you have any doubts about which colours are coming through do a Nozzle Check from the printer/printer software.
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jan 31, 2007
SOURCE: Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Anonymous
  • 3587 Answers
  • Posted on Mar 04, 2008
SOURCE: Canon Image Class MFC 8180c "Download Stanby"
that's not too good...let's get down to cases here
Anonymous
  • 685 Answers
  • Posted on Jan 17, 2009
SOURCE: canon ip5000 won't print black
try taking the cartridge out and cleaning it then replace it after that unplug it for a couple minutes and then plug it back in and let me know what happens
arjoy
arjoy ceniza
  • 95 Answers
  • Posted on Jan 20, 2010
SOURCE: Black ink cartridge is new but not printing
Was the code of the cartridge you put is correct? if not then replace it.if it is right, then check the nozzles, the printer heads and clean. some printer is equipped with cleaning tools software that might help you.
pineworks
Clive
  • 4362 Answers
  • Posted on Apr 28, 2010
SOURCE: Printer willl print color but does not print black and white
Hi There You can try/
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Konica Minolta Bizhub C452 Copier. Why does my Konica 452 cast a black shadow when printing?
Question edited for full make model name.
Question moved to model category.
Try this
Thread: Bizhub C450 Print Shadow!!!
Copytechnet https://www.copytechnet.com > ... > Konica Minolta
Sep 9, 2009 - Working with a Bizhub C450 that has started to print with a shadow on black and white prints. This problem does not show up on color prints.
How to remove printhead
Alignment shows black & streaky, only covers 3/4's of a line, color is good. The printer copies a document no problem; but only copies color (no black) from the computer. If the document is black print, I get a blank page. Do not know how to remove printhead
Dell printer won't print
It may have a date code ill not allow you to print without updating/replacing the cartridge. I got rid of hy HP for the same reason.
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
1helpful
2answers
Only wants to print/copy on Legal paper
check that someone hasnt moved the paper size dial blue 1 in paper trays then do get device status in driver for printing my moneys on the dial been moved
My HP 7410 will not print in color. Black
my hp printer officejet7410 made a wierd noise and now the only color that anything prints is in reds and pinks.
2helpful
2answers
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Can't print multiple copies
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
old marine
old marine
ZJ Limited
ZJ Limited
