I put password on hard disc every time i start it i have to input password how do i delete it?
Click "Start," then select "Run." In the text box displayed, enter "control userpasswords2" and press "Enter." This opens a configuration window. Click the user for whom you want to disable the password login. After selecting the user, remove the check mark labeled "Users must enter a username and password to use this computer." Click "Apply." A dialog box will prompt you for the password. Enter the user's password to authorize the changes and press "OK." Reboot your Windows XP computer. When it shows the list of user profiles, click the user whose password was disabled. You should be able to log in without a password.
also Click the "Start" button. Double-click "User Accounts." Select the user account you wish to change. Select "Change My Password." If you wish to remove the password, select "Remove My Password." also Click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. Just click In New password and Confirm new password, type the new password by just clicking, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
Hope this helps.
