Question about Tomtom GO 300 GPS Receiver
Battery My TomTom NORMALLY works on the internal battery or when pluged into the car battery or AC home charger. I normally leave the TomTom in the car on the mount. When I start the car the Tom Tom powers up. When I shut down the car the Tom Tom powers down. When the Tom Tom is running on the AC charger or the car battery and I disconnect the external power source it continues to work on the internal battery untill I power it down with the power switch. THE PROBLEM: TomTom worked fine today, went to work, shut off car. Got out of work start car, Tom Tom does not power up? Charge indicator is lit. Hold power button 3 seconds Tom Tom powers up and reboots as if the first time used. But then works fine and all personal info is intact. Drive home shut down car, Tom Tom does not go through normal shut down process just turns off (no shut down screen). Now if Tom Tom is hooked up to external power source it will boot up as if first time. If disconnected fron external power source it just goes off without normal shut down. If turned off manually with power switch but left on external power source when restarting it goes on normally (does not need to reboot. BATTERY strength indicator states Full Charge. Unit is out of warranty. I am not afraid to try to fix it myself if I know what to do. I can solder and have done minor repairs on other electronic items. Thanks for your help
  • swatts831 Oct 20, 2008
    Mine was working fine till one day it seemed as though the internal battery had become completely drained. I plugged it in and let it charge back up over night. The next day it powered on like it was the first time I had ever used it. Then shortly after, I got the screen that read "..... will now power down in 10 seconds". I could press cancel and it would go ack to the previous screen but it kept going back and fourth between the regular screen and the power down screen. I've tried to reset it with no help....
  • trisha1969 Nov 17, 2008
    i have a tom tom bought from a friend but it will not old the charge when i unplug in car and bring into my house there is no power how can i change the internal bat? help
  • 3 Answers
Need new batteries.
Posted on Oct 21, 2008
Where do I get battery?
Posted on Oct 22, 2008
  • 3 Answers
Hey Tom - I have a Go 300 that is about 1.5 years old and it just started doing this *exact* same thing a week or so ago. Have you found out what the deal is as of yet? I tried the reset button on the bottom, but it seems to have no effect. The unit will not work at all on battery power, and every time I start it in the car I have to hold the power button in and get the same thing you do. I also noticed that after it finally starts up, it takes between 1.5 and 7 minutes to acquire the sats.
Posted on Sep 25, 2007
6ya staff
SOURCE:
Unable to turn it on ,only lighted screen and connection ca be seen
First of all, make sure the battery is fully charged. If you're not sure your car charger is working, try charging it with a USB-cable on your PC/Mac.
Once the battery is charged, RESET your TomTom.
Old TomTom's have a RESET button on the bottom. One model has it's reset button hidden under a cover.
Newer devices don't have a reset button. You reset them by "KEEP PRESSING THE POWER BUTTON A LONG TIME"
Try pressing even more then a minute. Eventually you should hear the TomTom "Drumm Roll" (the starup sound), and your GPS would start normally.
If this doesn't work, Try updating the device firmware using a USB-cable and the right software depending your device. Older devices use TomTom HOME, never ones use TomTom MyDrive.
I wish you a lot of succes!
May 14, 2015 | Tomtom GPS
For some reason, I didn't get a home charger for my Tomtom One 130 when I got it for Christmas. Will my Motorolla phone charger work? Also, I cannot understand the diagram for installing it to the...
The plastic suction cup attaches to your windscreen. You can see more of the device in www.tomtom.com
Your Motorola phone charger will not work and it may even damage your GPS! In the package you have a cigarrette lighter adapter for your car - the home charger (AC-charger) you have to purchase separately.
Jan 06, 2010 | GPS
I plugged the system in, the screen would not come on
Hi.
First check the charger connection. If an alternative charger is available test different chargers.
If the Tomtom is starting, then try first resetting your TomTom.
To reset the TomTom follow the instructions on TomTom website, clicking here: TomTom, portable GPS car navigation systems - Factory reset .
If the Nav is still freezing or is dead after reset, then there is an internal fault.
In both situations the alternatives are going to a TomTom shop or calling the TomTom service number listed on manual and following the instructions given by their representatives.
If the unit is completely dead, as a first thing better going to a TomTom shop and asking to test a different charger.
The charger can also be tested at home using a multimeter on charger connector.
Regards.
Jan 03, 2010 | Tomtom ONE GPS Receiver
Do i need a special charger for the NE-720 internal battery
It needs AC-ES3010K2 ac charger to charge battery.
Click HERE and download user manual of Sony D-NE720 for further details.
Feb 08, 2009 | Sony D-NE720 Personal CD Player
Just bought tom tom 1 what do i do now need to download soft ware? how?
you can get the tomtom home software from
http://www.tomtom.com/plus/service.php?ID=17
please rate as fixya or leave a comment.
Jun 15, 2008 | Tomtom GPS
Tom tom not working
  1. First , try a re-set through the 'reset' hole underneath the tomtom. 1 quick short press is all thats required. Unlike others suggest , you do not need to hold it in for anything longer than half a second. You should feel the switch 'click' as its a tactile switch. Don't press too hard as you can damage the switch and cause it to lock ON. Once pressed , try turning the tomtom on as normal. Sometimes a tomtom battery can drop below its normal "shelf" voltage ( normal is about 3.8 volts ). A tomtom charger has a protection circuit inside to stop or slow the current it gives out if there is a short. If your battery HAS dropped volts TOO MUCH ( less than 3 volts ) the charger can "see" the tomtom battery as a "short" and the charger therefore shuts down and doesnt charge the battery. You could leave the charger connected and HOPE that the very small amount of current it's putting out will eventualy bring the battery up over 3 volts. Once it is up near its "shelf" voltage ( called shelf voltage as that is the voltage the battery is at 'on the shelf' ie . when its not powering anything ) the charger will begin to charge as normal....... OR ... you can gain access to the battery and charge it from a bench power supply that has voltage and current meters. Once again , once the battery voltage gets something near 3.8 volts the normal tomtom charger can be used to charge it. You caould connect another normal battery to the tomtom battery just for a few seconds ( not recommended and can be a bit dangerous ) if the normal battery is such as a PP3 9v type it should bring up the tomtom battery to over 3.8 volts in a few seconds. The tomtom can then be charged as normal. .............. It is also possible that some internal IC's ( chips ) have blown inside the tomtom and unfortunatly this would require a specialist repair centre to replace them as they are really very very small and are not a normal soldering job. Good luck. ... if this post has helped you or interested you please rate the author.
Jan 12, 2008 | Tomtom ONE GPS Receiver
How do I recharge my Tom Tom One?
I talked to TomTom support about recharging. They say that the unit uses more power than it gets, but if you turn the power off while the car is running, it will recharge.
Aug 28, 2007 | Tomtom ONE GPS Receiver
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Tomtom GO 300 GPS Receiver Logo
328 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
