Would it be the compressor start unit?
SOURCE: need help on Maytag Plus Ref
First check for a thick frost buildup on the back panel of the freezer at the bottom. Also, check to see if the fan in the freezer is running. Let me know what you find so I can lead you in the right direction.
SOURCE: maytag refmodel number mff2557hew
sounds as if perhaps the fan in the freezer is not circulating air up to refrig sect. pretty common issue, if you pull out freezer door youll be able to hear the fan on the back wall, behind the vent on top sect of freezer. that cover pops right off with a pry of the screw driver.. heres the part number if indded that is the issue 12002744 comes with instuctions on how to install
SOURCE: Refrigerator not cooling: Maytag Plus: Model MSD2756GEQ
Your PTC relay is bad and needs to be replaced. It is on the side of the compressor that connects the wires to it. Cost is about 50 maytag price or you could go with a 3 in 1 cost about 15. If you need any help get back with me and can walk you though it. Ken
SOURCE: refrigerator warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
