Received Error CA00 and message "call service"
SOURCE: Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
SOURCE: Toshiba e-studio 230 call for service
Call a Service tech
Have him reset yor Counter AFTER he over checks your copier and inspects the Drum,.Transer Unit, and Fuser Unit chances are the previous tech may not have reset the counter
but call for Service to verify those parts are good first ok. I would not want a counter reset to occur if a fuser unit is bad or something. At that low copies it maybe time for corona's to be replaced.
http://www.copierspluswwllc.com
SOURCE: Toshiba eStudio 2500c - CA00
This is a pretty complicated issue/problem. there are 5 pages devoted to this issue in the service manual. This issue would be best handled by a technician. but you could try the following....
[CA00] Color registration abnormality
<Color toner low density>
Turn on the copier holding down 0 and 8 and wait till it boots up into its service mode..then enter code 2692 “Prevention of color toner low density / change the zero to 1.
Then change code 2693 “Prevention of color toner low density / Judged number of sheets setting” value to 40 (default 20).
Make sure you have cleaned the main charge units by fully extending the rods with the green handles for each color.(open the front door) and use the plastic wand attached to the front door to clean the laser glass for each color..there is a small **** under each color unit to slid the wand into..felt side down on the wand.
Like I said there are several other complicated ways of fixing this.
