SOURCE: linksys password...
I think you are wrong , some model has blank password, for example:
SPA-3102
There is also some model that use blank username and password 'admin' to start administrator account.
(20 years selling and fixing this stuff)
It is possible default settings are different in different countries, I am in UK.
SOURCE: Username & password for WRT54G Linksys Router
As this is posted under WRT54G router - the default IP for that model really is 192.168.1.1
Look at the bottom of the router and locate :
(right under the word Linksys)
Exact Model and Version
If it is a WRT54G :
disconnect all ethernet cables leave it ON
Press and hold the reset button for 10 - 15 seconds (make sure all the lights flashes)
SOURCE: AirPlus Extreme Wireless G Router-Can't reset Username/Password
on this router, leave the username blank and enter admin in the password box.
SOURCE: linksys router G - buddy forgot password
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
SOURCE: username and password for your wireless router connection
You may need to hard reset it ; and reconfigure it again.
